Glass replacement - Drivers side front?
Old Feb 25, 2013 | 05:16 PM
brakeboost's Avatar
Exclamation Glass replacement - Drivers side front?
Whilst driving through Alabama during road construction the car in the next lane threw a good sized rock at my drivers side front window. Since its laminated it's still in one piece, but the cracks have migrated to the ends of the window after several hours driving. I have a replacement from eBay on its way for $80 inc shipping, as opposed to around $800 from Safelight. Has anyone change one of these before?
Old Feb 26, 2013 | 03:47 AM
meirion1's Avatar
I have replaced a lock in the rear door.
You will need to remove door card and then moisture barrier (solid plastic sheet} inside to give you access to the glass.
It is not difficult but takes time and try not to break plastic clips.
I suggest you check operation of window prior to replacing door components.
Lucky it was not the windscreem or bodywork IMO.
Old Feb 27, 2013 | 08:31 AM
brakeboost's Avatar
Thanks, I am assuming the door card is secured with screws around the areas where you pull as with other makes? I don't know how Jag secures the glass, but when I get in there I'll take some pics to post.
xjrjag
May 21, 2026 09:05 PM
Malihide
Apr 11, 2026 02:58 PM
johanasu
Sep 3, 2015 12:39 PM
frankc
Sep 1, 2015 04:41 AM
xk8don
General Tech Help
Aug 29, 2015 11:10 AM
