Headlight hid issues
Old Sep 3, 2012 | 02:40 PM
XJRPro's Avatar
Exclamation Headlight hid issues
I experienced a flickering HID Bulb on the driver side days later it went out. I went and bought a new bulb and checked the fuse after i replaced the bulb and it didn't work I even took it back for another to check for defects. There is a new hid ballast AND BULB AND THE THE DRIVER SIDE HEADLIGHT IS NOT COMING ON.. HELP ......
Old Sep 3, 2012 | 05:36 PM
Thermo's Avatar
Veteran: Navy
XJRPro, what year and model is your car? How are you with a multimeter? I can help you diagnose what is going on with your vehicle if you give me a little bit of information. Based on what you are describing, it is sounding like a fuse that is causing a voltage loss, causing your problems. I would say to swap the DIP beam (what us Americans call low beam) fuses and see if the problem moves side to side. If it does, then it confirms the fuse is your problem.
Let me know if you want more assistance. If you are not very familiar with a multimeter, state so and I will give you step by step instructions of what you need to do.
Old Sep 3, 2012 | 11:01 PM
XJRPro's Avatar
Exclamation
Thanks Thermo, I have a 2006 Jaguar XJR I tried swaping the fuses and checked the fuses there were no burnt spots or gaps and the driver side did not come on. I am good at figuring tools out I can get my hands on a multimeter.
Old Sep 4, 2012 | 05:20 AM
steveinfrance's Avatar
I've moved your post to the XJR section.
Please put your car's details in your signature so experts (like Thermo) can help you better.
Old Sep 4, 2012 | 11:26 AM
XJRPro's Avatar
Exclamation 2006 Jaguar XJR HID ISSUES
Old Sep 6, 2012 | 11:48 AM
XJRPro's Avatar
Default Any sugesstions
driver side hid will not cut on any suggestions fuse is good
Old Sep 6, 2012 | 10:10 PM
billyat1018's Avatar
Default 2006 XJ8 HID's wont work
The drivers side bulb quit working, so I ordered 2 new Phillips bulbs. I changed both, now I have no low beams. I checked the fuses and the connectors and all are good. I tried to remove the whole light bucket but could not figure it out to check the main connection . If anyone has any thoughts it would be greatly appreciated. Thanks Billy
Old Sep 10, 2012 | 08:45 AM
androulakis's Avatar
You need to check your ballasts.
The one u said worked until the bulb swap? If you know which bulb that is try it on each side.
Start there and we'll move forwards.
Take care,
George
Old Sep 23, 2012 | 07:33 PM
Default Ballast hunt
Thanks for your response George. I have been too busy to work on the car.I rcleaned the blades on the fuse for the passenger side and got it working. The driver side was still out so I bought a replacement ballast but am unable to find it on the car.
Can anyone tell me where to look and how to get there. Thanks Billy
Old Sep 23, 2012 | 09:39 PM
Casper's Avatar
The ballast is mounted to the underneath of the headlight housing. You have to take the bumper off to remove the whole headlight housing. Also before you do those trying checking your ground wire that is mounted behind the headlight on the frame.
99xk8guy
May 28, 2024 09:36 PM
redrover41
23
Sep 25, 2015 01:33 PM
afterburner1
General Tech Help
Sep 7, 2015 08:43 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
laserguy
Sep 3, 2015 02:02 PM
