headlight restoration kit
Old Jun 14, 2009 | 02:49 PM
radiantxj's Avatar
Default headlight restoration kit
I was thinking about ordering a 3M headlight restoration kit to clean up the headlights on my 04 XJ8. Anyone out there used this, and if so, how satisfied were you with the results? Also, looking at the car it looks like I might want to remove the front bumper to get better access to the whole headlight area. How involved is removing the bumper? Thanks.
Old Jun 14, 2009 | 04:06 PM
hlgeorge's Avatar
The kit you refer to is, I believe, for plastic lenses. The Jag has glass lenses.
Old Jun 15, 2009 | 07:33 AM
radiantxj's Avatar
I must be looking at headlight covers then, because I'm definitely looking at plastic.
Old Jun 15, 2009 | 08:36 AM
03JagSTR's Avatar
The kit you mentioned should work fine. I did a similar process that is detailed in the following link......
http://www.associatedcontent.com/art...ing.html?cat=6
Old Jun 15, 2009 | 02:30 PM
radiantxj's Avatar
Thanks 03JagSTR, I was looking for reassurances before I took sandpaper in hand.
Old Jun 15, 2009 | 04:58 PM
mitch.thompson's Avatar
radiantxj, on your XJ headlights, are you referring to a "glazing" effect on the upper 1/4 or so of each of the headlamps? If so, I've got that condition, as well (see photo). How well did this stuff work?
Thanks, Mitch
Old Jun 16, 2009 | 07:11 AM
radiantxj's Avatar
Mitch, I do have the glazing on the upper part of my headlights like yours, but not quite as thick. I have been told it's mostly oxidation or caused by UV rays-my car was florida owned before I bought it. I just ordered the kit off EBAY, haven't received it yet.
Old Jun 16, 2009 | 09:58 PM
hey radiant....check out the hazy headlight remedy FAQ in the x type faq quick link section I think.
Good luck
Old Jun 17, 2009 | 05:48 AM
Thanks, looks like I'll be polishing headlights this weekend...
Old Sep 22, 2009 | 07:40 PM
Innovative Detailing's Avatar
Default Proper Headlight Lens Restoration Techniques
Here are a couple of helpful Youtube videos I have put together demonstrating the proper techniques that I employ for headlight restoration on a Porsche Carrera and a V.W. Jetta
http://www.youtube.com/watch?v=6Ab8aRZ9mAA
http://www.youtube.com/watch?v=260TxpkxgOk
Also I attached 2 pics of a 2000 Jag Type S that I did today that required this service......
What a difference before the correction Name:  DSC_0808.jpg
And after the correction Name:  DSC_0864.jpg
Dave @ Innovative Detailing
Old Sep 24, 2009 | 07:35 AM
Clifsmith's Avatar
I used this kit and it worked like a charm. $24 at autozone.
Old Sep 24, 2009 | 08:00 AM
mooreman6's Avatar
I used the 3M headlight restoration kit on my 2004 XJR, which included step 1 of sanding. It worked perfectly, my lenses look crystal clear. The kit can be bought at Walmart for $18 or Advanced Auto for $21.
Old Sep 24, 2009 | 02:00 PM
KruBruder's Avatar
I have yet to see an X350 with hazed lights. It made me wonder if they were different materials than other Jags. I know my '05 VDP has plastic lenses. I see X-types ans S-types all day long with lenses so hazed that I wonder how they can see at night. Good info here though.
Old Sep 25, 2009 | 08:07 AM
Clifsmith's Avatar
Autozone sux. I am not buying there anymore. Their pricing is ridiculous. I bought a 5 gal jug of Castrol Syntec motor oil at Autozone for $33 and fram filter $9.50. I was at walmart shortly after and looked, same oil was $22, filter $8. now $18 for the same headlight kit I paid $24 for. I sent a complaint to corporate about their pricing and they said see the store manager. The store manager DOES NOT control pricing. What a joke. I hope they go bankrupt.
Old Nov 19, 2011 | 07:05 PM
vserduchka's Avatar
+1 on the 3M kit. My 04 XJ8 looks like new after a detail!
Everything you need to get the job done. Only other tool I needed was a drill and some water.
Before:
After:
Not too shabby!
Old Nov 19, 2011 | 09:51 PM
SuperTrav's Avatar
My concern is the UV protection factor, or lack thereof. I have done some great reading on various threads on Jaguarforums that indicate that this process will need repeating every few months, unless a UV inhibitor is applies as a final step. What are your thoughts along these lines?
Old Nov 20, 2011 | 06:02 PM
oldmots's Avatar
Just wax the lenses with Meguiars high tech wax, then they will need rewaxing whenever you wax the car. Mine have gone a year with no more oxidation with waxing every 4-5 months.
Old Nov 20, 2011 | 09:45 PM
SuperTrav's Avatar
When I was buying and selling used cars, I used to restore headlights with 3 progressively fine grit wet/dry sandpaper, then old fashioned polishing compound, then 3M glaze with a wool pad on my Milwaukee HS polisher, and then wax. In fact, I still have everything but the sandpaper. I think I'll go this route on my "R" after all, as I have some light hazing on the upper portions of my HID's.
Old Nov 20, 2011 | 09:49 PM
jahummer's Avatar
I had mine permanently repaired by a body shop for around $60. Sanded & UV clearcoat. EVerything I know of the sand polish and wax kits over the counter is they do not last very long and require constant maintenance making it more costly over time.
bdboyle
Sep 16, 2019 05:58 PM
GGabriel
Nov 22, 2018 03:53 AM
kevinl
Sep 24, 2015 08:25 PM
1964Daimler
Sep 9, 2015 11:28 AM
sklimii
Sep 5, 2015 06:04 AM
