Heating Problems
Old Jan 19, 2018 | 11:13 AM
garethashenden's Avatar
Default Heating Problems
I've had some heating problems with my '04 XJR. Not uncommon, but I'm out of ideas. There was no heat, so I replaced the auxiliary water pump. After that there was some heat on the passenger side. So I replaced the heater core. Now there is some heat on both sides, but it's not exactly hot. I have the temperature set at 88F and the air coming out of the vents is low 60s. What else is there to do? Are there valves that fail? Is there something else that causes problems? The system is fully bled, so I don't think there is an air pocket somewhere.
Thanks!
Old Jan 19, 2018 | 04:08 PM
meirion1's Avatar
Possible failure of water pump vanes or possible partial blockage of thermostat housing (plastic). I suggest that you should replace the thermostat first.
tajsingh
Dec 1, 2017 04:47 AM
marvin67
Nov 1, 2016 07:40 AM
JulianXJ6
Jul 14, 2013 01:04 PM
sandman66
Jan 13, 2013 02:34 PM
1985jag
May 29, 2009 09:49 AM
