Heating Problems
Old Jul 13, 2013 | 11:34 PM
JulianXJ6's Avatar
Default Heating Problems
Hi Guys,
old car - new Problem..... AC is working well & cooling down, but I'm not getting any hot air if I turn the temperature up....
checked fuses for faults & all seem ok.
Any ideas?
cheers Julian
Old Jul 13, 2013 | 11:45 PM
sparkenzap's Avatar
There is an auxilliary water pump located on the left side of the car near the firewall that circulates water for the heater circuit. Adjacent to it is a valve that controls the flow of water to the heater circuit. The pump is known to wear out brushes and the valve can stick. Have a look in the archives for info on replacing the heater pump brushes or cleaning the heater valve. Note- the heater valve powers OFF for hot water flow.
Old Jul 14, 2013 | 12:19 PM
mikesmith2's Avatar
Thermostat could be stuck open, not allowing engine to get up to operating temp.
Cheap and easy to do.
Old Jul 14, 2013 | 12:58 PM
Doug's Avatar
Typically evidenced by the temp guage not coming up to a normal reading.
I had this happen on mine. Of course it was on a road trip in the dead of winter !
Old Jul 14, 2013 | 01:04 PM
FireCrow's Avatar
yup, I agree with the faulty thermostat... I changed mine just before road trip across Europe, but I managed to crack the housing, as I wasn't tightening the bolts evenly. I kept dripping slowly, and every 400km I was topping up the coolant. Then eventually I got some 2part 'glue' for steel, and that did the trick So just be careful when tightening those 2 bolts
H20boy
Dec 24, 2024 03:23 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
Bcrary3
Sep 3, 2015 03:48 PM
laserguy
Sep 3, 2015 02:02 PM
