HELP!! 2003 Jaguar coolant problem!
Old Jan 15, 2019 | 10:47 AM
noah zane wars's Avatar
Default HELP!! 2003 Jaguar coolant problem!
so my 2003 Jaguar XJ sport/8 is leaking coolant from the bottom hose underneath the coolant resivor and it only leaks when the heater is on. Almost as if the heater is making pressure in the system and pushing coolant up through the top of that hose. Heater works perfect and the car does not overheat at all or stay to cool. Thanks
Old Jan 15, 2019 | 11:12 AM
NBCat's Avatar
After the vehicle cools down, preferably overnight, pressurise the cooling system to one bar and look for leaks. The expansion tanks are made from plastic and can only withstand a finite number of cold to hot to cold cycles before failing.
Most likely the tank has a crack that opens when the system in under pressure.
Old Jan 15, 2019 | 11:31 AM
Default Thanks for the reply!
so why would it only do it while the heater is on? It’s weird I can have the coolant cap off and run the car and the level will be fine but as soon as I turn the heater on it wants to overflow everywhere!!
Old Jan 15, 2019 | 11:40 AM
NBCat's Avatar
Use a wireless Bluetooth scanner and Torque app with a smartphone to monitor coolant temperature. DO NOT rely on the instrument cluster gauge to accurately tell you if the engine is overheating. The gauge may not indicate a rise in temperature between 86 C and 129 C.
If there was recent work to the engine that involved draining and refilling the cooling system, it may have some air trapped. Bleed the system using the procedure outlined in the Workshop Manual, or use the search function on this forum to find other threads discussing the issue.
Filthpit
May 7, 2018 02:08 AM
Harry Peter Rose
Feb 13, 2018 08:14 PM
George Elton
Jan 17, 2018 06:38 AM
JCHouston
Jun 25, 2015 10:31 AM
colin3342
Apr 19, 2013 08:43 AM
