Help... EGR Removal
Old Mar 8, 2009 | 12:40 PM
kmschaer's Avatar
Default Help... EGR Removal
Hopefully a tech will read this soon. I am attempting to remove the supercharger from a 2004 XJR. The EGR valve and tube needs to be removed to access the lower bracket bolts on the air intake elbow. As a competent mechanic, I am at a loss as to how to access the exhaust manifold EGR bolts and the EGR to Air intake elbow bolts.
Any ideas would be greatly appreciated.
Old Mar 18, 2009 | 11:59 AM
kmschaer's Avatar
Default Major pain...Job Complete
Working to remove my XJR Supercharger, mid way through it says to remove the EGR.... Not exactly easy. I came very close to stripping the 8mm bolt head to the air intake using extensions, U Joints, knuckle ratchets, combo wrenches, divine intervention, etc.... If anyone is interested, I finally found the right combination (which sounds easy when done). I used a 3/8" drive six point socket and a 3/8" stubby (2 1/2") ratchet to snake behind the air intake elbow to the EGR.
Let me say, I am a huge believer in 6 point sockets now instead of the 12 point. The bolt finally broke loose, and, to my surprise, I did not have to remove the exhaust mainfold bolts since the Jaguar engineers kindly made that last 3" of the EGR with an accordian so that I could move the EGR out of the way to access the SC bolts.
I was then able to get the SC off and repaired.
BTW... Jaguar ONLY offers a complete supercharger. They also do not offer a replacement pulley. A new aftermarket pulley is $ 245. So, be careful if your remove the SC pulley.
Old Dec 25, 2011 | 10:38 AM
gocallahan's Avatar
Hey kmschaer,
You removed the supercharger without removing the intake elbow?
How did you do this!? I am looking at teh job right now and have everything removed except intake elbow to finally remove SC.
I am missing teh JTIS instructions on how to remove teh intake elbow, you wouldn't have those would you? JTIS #19.70.28
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
mhamilton
67
Apr 1, 2021 03:20 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
XFR_Gold
Sep 2, 2015 12:24 PM
