Help me bluetooth
Old Aug 6, 2010 | 10:31 PM
rocketbuilder's Avatar
Default Help me bluetooth
every time I hit the phone button on the dash on my 2005 VP I get this mesage.
handset in use
mute and replace handset to
contunue hands free use, or
replace hand set to end call
help me please
thanks
Old Aug 7, 2010 | 12:09 AM
JagMaster's Avatar
handset in use
help me please
thanks
Turn the ignition on and wait for 20 seconds before you start the car, in that time period ask your self " do i really need bluetooth?" if you say "yes" then restart your phone and when its back on , go to settings and erase "jaguar" from the paired devices list. Then re-pair it with your jaggy it should be fine. If this doesnt help you , turn off the ignition and get outta car , get on your computer and reply this message.
Old Aug 7, 2010 | 02:06 AM
no didn't work,
handset in use
this stays on the screen.
can't get into pairing mode.
Old Aug 7, 2010 | 02:15 AM
JagMaster's Avatar
Very well, go unplug the car battery then plug it back ,it will probably reset the radio and stuff, then it must be fine if even this doesnt help then take it to dealer
Old Aug 7, 2010 | 03:06 AM
veffremov's Avatar
Rocket, are you sure you have bluetooth installed?
I got similar message when I had only the Phone module in the trunk, but no bluetoot radio in the center console.
The BT is a bit of a hack. The car was designed to have a telephone installed in the center console. The BT radio gizmo emulates the V60 Motorola phone. If you don't have either the phone module in the trunk is just confused and you get this message.
If you do have BT, check the connection between the BT module in the center console and the PSE in the trunk, may be your cables are giving you grief.
Hope this helps,
Venelin
Old Aug 7, 2010 | 04:00 AM
JagMaster's Avatar
Damn he has VDP and VDPs better come with bluetooth modules, you guys are paying some good $$$ for them, even my jag has bluetooth
Old Aug 7, 2010 | 09:52 AM
@ Jagrmaster, left battery disconnected all night did'nt work.
@Venelin blutooth worked fine till last week.
thanks for helping.
Old Aug 7, 2010 | 10:05 AM
I pulled the rear vents and disconnected the Bluetooth module still get the same message.
handset in use
continue hands free use, or
and then I disconnected phone module now I get
Phone not fitted.
out of warranty please help
Old Aug 7, 2010 | 12:47 PM
veffremov's Avatar
Rocket
By disconnecting the battery, you performed all computer "resets" you could do.
You establshed your BT module behaves as if it's disconnected. My humble guess would be either cable between the BT module and the PSE, or the BT module is dead.
You could also go to a dealer and pay $150 for proper diagnostic. The jag diag software can do more sophisticated resets of computer data.
Best of luck,
Venelin
Old Aug 9, 2010 | 05:01 PM
XJ8JR's Avatar
"Do I really need bluetooth?" Priceless. That made my day, Jagmaster.
Jagzzz
Aug 8, 2021 02:45 PM
sg997tt
Oct 9, 2015 10:57 PM
Msteiner
Audio/Visual Electronics
Sep 30, 2015 08:36 AM
42Ajd
Sep 26, 2015 07:04 PM
