Help needed diagnosing DSC/ABS fault. Too many codes!
Old Feb 9, 2020 | 12:49 PM
mesaboogieman's Avatar
Default Help needed diagnosing DSC/ABS fault. Too many codes!
Hi all.
on my 2003 XJ8
I have abs and dsc lights on, also ‘dsc inoperative’ message. These are the fault codes as read by a snap on diagnostic. Would appreciate some help on this as there are so many codes its hard to know where to start!C1165 wheel speed sensor rear right input circuit fail
C1175 wheel speed sensor rear left input circuit fail
C1280 yaw rate sensor signal failure
C2778 sensor power supply failure
P1260 security input
P1582 flight recorder data is stored
U1027 SCP(J1850) invalid or missing data engine rpm
U1040 SCP(J1850) invalid or missing data vehicle speed
U1058 SCP(J1850) invalid or missing data vehicle transmission
5200H/20992 undocumented code
Old Feb 9, 2020 | 03:12 PM
paddyx350's Avatar
Replace the wheel speed sensor
It's easy and doesn't cost much
Reset the codes and go from there
Old Feb 9, 2020 | 03:20 PM
Thanks for that.
Seems strange that both rear sensors and the yaw rate sensor could all be faulty but I’ll probably try replacing them all for starters. No info from the engine Rpm, vehicle speed and gearbox is a bit of a worry, I’m trying to think of a common fault that would cause all three
Old Feb 10, 2020 | 03:37 AM
EsRay's Avatar
Originally Posted by mesaboogieman
Thanks for that.
You could consider clearing all the faults to see which of them come back again before spending a penny?
Would have thought you would flag a CATS System or Suspension fault if those codes are all still present?
Some of the codes could be caused by a battery 'dip' at startup?
Old Feb 10, 2020 | 03:49 AM
We cleared them and they all came back. The battery seems fine.
Old Feb 10, 2020 | 04:10 AM
EsRay's Avatar
Understood, but please keep in mind that the DSC/ABS fault can often be tripped by a battery dipping under starting load?
Old Feb 10, 2020 | 04:12 AM
The yellow brake warning light never goes and the dsc light comes back on after driving a short distance.
Old Feb 10, 2020 | 03:47 PM
meirion1's Avatar
+1
Old Feb 10, 2020 | 07:23 PM
Wingrider's Avatar
What is the voltage on your battery?
A voltage drop test will tell the condition of the battery.
Just because it starts the car means little.
Old Mar 24, 2020 | 03:44 PM
JagMan2020's Avatar
What was the prognosis? I think my parents 2007 XJ8 is having the same issues. Lots of faults coming across.
Old Mar 24, 2020 | 03:56 PM
It seems the previous owner was messing about with the JLR SDD software when the battery ran down resulting in at least three different control modules being corrupted. Now they wont talk to the diagnostic so theres no way of resetting them.
I only got it as a cheap project to tinker with, but its going to take way too much time to sort out so unfortunately its got to be sold as is.
dbrowdy
Jan 31, 2020 08:20 PM
piroboot
May 31, 2018 04:51 PM
Count Kasador
Apr 8, 2018 02:57 PM
Peperami
Feb 7, 2015 07:18 PM
Andy
Jan 9, 2009 04:36 PM
