Help please
Old Jan 6, 2026 | 05:04 PM
Cjettk's Avatar
Default Help please
What are these and where do they go?!?! Please and thank you.
Old Jan 6, 2026 | 05:26 PM
RoverJoe's Avatar
Community Influencer
To your air/dynamic shocks that have been removed, from the look of things.
Old Jan 6, 2026 | 09:19 PM
Big Koshka's Avatar
+1 Airshocks have been removed and replaced with coil overs.
This is what air suspension looks like from same vintage point:
Old Jan 7, 2026 | 09:41 AM
wfooshee's Avatar
They don't go anywhere any more. The failed air suspension system has been replaced with steel coils, which is a Goode Thing.
Old Jan 7, 2026 | 10:37 AM
Cjettk's Avatar
Awesome, understood. Thank you very much
Old Jan 8, 2026 | 05:40 AM
Petz's Avatar
Wrap them with isolator and leave like it is , just to keep the possibilety to mount airsuspension struts again later on yourself or someone else.
air compressor is at the front left side behind bumper , 4mm nylon hose going from there to the boot from below car into Valvebody at tank inside boot below the sparewheel and styrofoam protection. And from Valvebody with 6mm nylon hoses to front struts and 4 mm hoses to rear struts.
then there is a Wabco Airsuspension module behind the rear back seat .
Total weight probably 12 kg so just not worth the effort .
Airstruts are lighter than coilovers
saly
Dec 25, 2025 10:53 AM
04Xjrsteve
Jun 16, 2024 04:11 PM
NYCJAG2006
Nov 23, 2023 12:24 PM
ericisback
E type ( XK-E )
Nov 4, 2021 01:04 PM
jaehoonhan
Aug 14, 2021 03:44 PM
