High pitch windshield noise
Old Apr 24, 2011 | 03:34 PM
glenlake's Avatar
Default High pitch windshield noise
Just bought a 2006 XJ8. When I get up to 60mph, I start to hear a high pitched vibration, similar to a whistle. Sounds like it may be a seal issue on the windshield. If I press on the top portion of the windshield, the sound stops. any ideas?
Old Apr 24, 2011 | 03:39 PM
plums's Avatar
You probably nailed it.
You could try sealing from the glass to the body and over the trim mouldings all the way around, and including the little gaps at the ends near the doors using masking tape. Then go for a drive. If the noise is gone, you know for sure.
Then it is just a matter of taking it to a glass shop to get it resealed.
Old Apr 24, 2011 | 05:14 PM
Road_King's Avatar
...pluck a feather from a feather duster. While you are going at a safe warp speed, have someone put the feather against the suspected areas on the windshield enclosure. Voila, you should find the leak.
Old Apr 24, 2011 | 06:00 PM
u102768's Avatar
There was a Jaguar TSB that addressed this issue (see attached).
Old Apr 24, 2011 | 06:26 PM
plums's Avatar
Seems like a useful procedure even for the corrosion prevention benefits.
One more job to add to the to-do list.
Old Apr 24, 2011 | 07:39 PM
glenlake's Avatar
Looks like I'm too new to the forum. Can't open the file.
Old Apr 24, 2011 | 08:07 PM
plums's Avatar
You need 10 posts in total.
But, it basically says:
1. "Clean area behind the flip seal in preparation for the glazing compound application."
2. "Apply 3M™ Auto Bedding and Glazing Compound 08509 under the flip seal to
prevent vibration of the seal at high speed."
The flip seal is the rubber seal around the windshield, and it vibrates at high speed. The sealant holds it down.
If you are a dealership mechanic doing this on warranty, you are allowed a whole 12 minutes to do the job
Old Apr 24, 2011 | 08:22 PM
glenlake's Avatar
Thanks Plumsauce
Old May 2, 2011 | 02:05 PM
in2's Avatar
in2
here in Blighty you'd just run it to the nearest windscreen company and they'd run their sealing gun right round for next to nothing !
Old May 2, 2011 | 02:43 PM
amcdonal86's Avatar
I thought the 2006+ don't have moulding around the windows like the 2004-2005 models do.
Old May 2, 2011 | 02:45 PM
hlgeorge's Avatar
The 04 is the only model that had the front and rear glass chrome trim. I really like too!
HypnoGuru
Oct 23, 2018 09:53 AM
1LowCat
Feb 23, 2016 07:19 AM
CaneCounsel007
Nov 13, 2015 09:05 PM
tsimms7
Sep 15, 2015 12:43 PM
hen555
Sep 7, 2015 11:13 PM
