Hopefully easy fix/electrical
Old 12-28-2007, 04:35 AM
xdave's Avatar
Default RE: Hopefully easy fix/electrical
Could you confirm if this is an X350 model, or the previous one?
If the X350 then the passenger puddle lamp is lit by the front electronic module, whereas the driver side is lit by the driver door module and the rear doors are lit by the rear electronic module. Each respective module is also responsible for each door ajar switch, which is the input signal for turning on the lamps.
Because all of the lamps come on when the passenger door is opened, it sounds like the other two modules are not receiving their respective door ajar signals. There is no common wiring between them.
When do the footwell lamps come on, when any door is opened or only with the passenger door?
If the pre-X350 model then each door has its own control module which handles both the door ajar switch and the pudle lamp. There is no footwel lighting as far as I can tell from the schematics. Again because all of the lamps come on when the passenger door is opened, it sounds like the other modules are not receiving their respective door ajar signals. There is also no common wiring between them.
My first check would to be try and find out if there is a common problem with the door ajar switches failing, coroding, or otherwise not working either for electrical or mechanical reasons. I can't help you there buthopefully someone will come along shortly who will know, otherwise phone your local dealer to ask. I think it is unlikely that two (or three) separate modules would fail with the same symptom.
Old 12-28-2007, 03:59 PM
xdave's Avatar
If you 'PM' me your e-mail address, I will send you PDF copies of the entire electrical quides (which include all the schematics) for both pre and post 2004 models. (That covers the older model and the X350.) Those are the schematics I used to write my earlier reply, and indeed I use them constantly when playing with my own cars. They come to 12MB together so make sure your e-mail mailbox will allow them if you are using a free or hosted service.
I believe (this is a guess based on observation and may be incorrect) that if the end of your VIN number starts with an G or Hit is an X350, if it is F it will be the model before.
Old 01-07-2008, 07:11 PM
03 would definitly be X308. Also the 4.0 V8 gave it away. Xdave is correct that each door has its own module, I would look first at the instrument pack and see if it says door ajar when you open them. Possibly bad door latches?
Johnken
04-08-2018 10:21 AM
n2audio
17
10-09-2015 10:53 PM
ArtyH
10-02-2015 11:39 AM
convincor
10-01-2015 05:19 PM
Moghut
10-01-2015 01:55 AM
Quick Reply: Hopefully easy fix/electrical
