Idle problems XJ8
Old Apr 11, 2025 | 10:50 AM
MartinM.no's Avatar
Default Idle problems XJ8
I have an idle problem with my XJ8 3.6. No warning lights. When cold no problems. When warm the car can drop in idle to 5-600 rpm almost as if the engine dies then back to normal.
The pattern is that the idle drops for a second or two, back to normal again, then drops, back to normal and so on. This cycle last for typically 30 seconds and then the car settles to a normal idle. If I then rev the car it can go back to the unstable idle before back to normal.
Otherwise the car runs and drives well. When it is down on rpm it feels like the engine is choked rather than a misfire on some of the cylinders.
Any suggestions? I have checked for vacuum leaks, lose wiring etc.
br Martin
Old Apr 11, 2025 | 11:15 AM
NBCat's Avatar
What is the fuel pressure during the erratic idle events?
Old Apr 11, 2025 | 12:43 PM
MartinM.no's Avatar
not sure. Can I read it from the obd reader or do I need a gauge and read it from the fuel rail??
Old Apr 11, 2025 | 01:02 PM
NBCat's Avatar
Use a smart phone with the Torque app to connect the vehicle's ECM/PCM with a Bluetooth interface through the OBD port. Read the fuel pressure directly.
Old Apr 11, 2025 | 01:40 PM
MartinM.no's Avatar
oki Thanks I have icarsoft reader so I can read pressure. Around 380 I think
Old Apr 13, 2025 | 03:59 PM
Jacuar's Avatar
Hi Martin,
I am not sure which units you are using, but fuel pressure should be around 55 PSI.
Old Apr 13, 2025 | 11:16 PM
h2o2steam's Avatar
KPA .........380 converts to 55 PSI
Old Apr 14, 2025 | 05:57 AM
OldKarz's Avatar
What are your fuel trims showing?
Old May 10, 2025 | 02:24 AM
MartinM.no's Avatar
As mentioned the car idle has been erratic but no fault codes. Car has also been very sensible on the throttle pedal - very snappy sometimes like a ketchup effect.
When I got the tip trying to change the throttle position sensor I decided to give it a go also linking the idle problem.
Bingo - now the car runs smoothly again on idle and throttle is much easier to modulate.
So if you have a throttle which is very sensitive and an unstable idle the culprit might be the tps.
Old May 10, 2025 | 05:35 PM
jerry_hoback's Avatar
Thanks for posting this. an excellent tip. I think you meant 'sensitive' and not sensible though, maybe?
Old May 11, 2025 | 01:42 AM
MartinM.no's Avatar
hi hi you ar right 😀
Old May 18, 2025 | 04:24 AM
Thermite's Avatar
Thanks for that! Been in 'avoiidance mode' over nearly identical ......if still 'sporadic' issue.
Old May 18, 2025 | 05:47 AM
MartinM.no's Avatar
mine was also sporadic, but getting worse and worse
user 7508230
Feb 15, 2024 06:42 AM
rtmyers1
Mar 12, 2022 09:34 AM
sailby
Dec 13, 2021 03:09 PM
Harry Dredge
Nov 2, 2015 12:31 AM
