Ignition Coil Ground
Old Jan 29, 2024 | 11:00 PM
EsRay's Avatar
Default Ignition Coil Ground
Dear Forum,
My ignition coils were replaced with OEM new 26,000 kilometers ago. Recently, I have had Restricted Performance flash up, (together with the resultant engine stumble), then disappear within seconds? This only happens at idle?
Codes have been firstly P0356 for coil 6, then P0358 for coil 8. I don't think the problem is the coils; could it be a poor ground?
Please, can anyone tell me where I find this ground point:
Old Jan 30, 2024 | 01:11 PM
Pete M's Avatar
Originally Posted by EsRay
Dear Forum,
Hi EsRay
Here is the pic of the grounds. I think it is either 26 or 30 depending on LHD or RHD.
Pete M
Ignition coil earthing
Old Jan 30, 2024 | 08:14 PM
xalty's Avatar
these coils have a feedback wire to the ecm that sets driver circuit codes...they're probably bad
it's kind of backwards but they ground to the body, use a sealed beam light to test it. if you want run an extra ground somewhere on the heads
Old Feb 2, 2024 | 05:53 AM
EsRay's Avatar
Originally Posted by Pete M
Hi EsRay
Pete M
Old Feb 2, 2024 | 05:58 AM
EsRay's Avatar
I'm sorry xalty, but I didn't understand any of the above; please could you explain what I need to do as if to an idiot?
Thank you!
Old Feb 2, 2024 | 02:57 PM
Rickkk's Avatar
Just replace the # 6 & # 8 coils as they're likely defective. Actually, I got through replacing the # 1 coil on my 2005 Jaguar XJ8L a couple of months ago, and that coil was replaced only 3 years ago.
Old Feb 11, 2024 | 12:03 PM
RussC's Avatar
Default Great post
Thank you for this diagram. There are a couple i dodnt know about
Old Feb 20, 2024 | 08:45 PM
Don B's Avatar
Hi EsRay,
Have you checked the coil connectors to confirm they are securely latched, and if so, that their electrical contacts are not contaminated?
Cheers,
Don
Old Feb 21, 2024 | 04:17 AM
EsRay's Avatar
Originally Posted by Don B
Hi EsRay,Have you checked the coil connectors to confirm they are securely latched, and if so, that their electrical contacts are not contaminated? Cheers, Don
Thanks Don; I have replaced 6 & 8 with new. Not an easy job because I found that someone had overtightend the hold-down bolts (should be just 5 NM) so that the brass inserts just spun when I tried to loosen them!
Old Feb 21, 2024 | 04:54 AM
Wingrider's Avatar
Without looking i don't remember if the brass inserts are mounted in plastic.
If so once the bolt is removed, a heated soldering iron, held on the insert.
Will soften the plastic, & it will regrasp the insert when cooled.
Discovered this working on motorcycles, they use plastic everywhere also.
Hope this helps
Old Feb 21, 2024 | 10:27 PM
EsRay's Avatar
Discovered this working on motorcycles, they use plastic everywhere also.; the bolts would just keep on turning. Hope this helps
Thanks Wingrider, the brass inserts are mounted in 'cups' in the plastic cam cover. The only way I could remove the ignition coils was to force them up with the knurled brass insert still attached to the ends of their bolts; (bolts would just keep on turning). I then epoxied the inserts back into place and tightened to the correct 5 Nm!
vmaxie
Jul 23, 2022 12:02 PM
a1lry
Jul 20, 2018 02:04 PM
Iconoclast
Jul 17, 2018 06:14 AM
