I'm noticing a very slight grinding at low speeds
Old Jun 14, 2011 | 03:14 PM
Jsedita74's Avatar
Default I'm noticing a very slight grinding at low speeds
I'd say at around 5-15 mph. I feel it under braking and under acceleration. Any ideas or thoughts ? I'm thinking front wheel bearings? At first I thought rotors or pads but it's under acceleration as well... Thanks fellas !!!!
Old Jun 14, 2011 | 05:43 PM
hlgeorge's Avatar
I hate to say it, but it is very hard to recommend issues with noises. What a noise sounds like may be different for each person. Is there a way you can record the noise and post it?
Old Jun 14, 2011 | 05:48 PM
Jsedita74's Avatar
Not necessarily a noise more of a grinding kinda like metal on metal . Something you would feel like when ya riding the brakes metal on metal.
Old Jun 15, 2011 | 09:39 PM
hlgeorge's Avatar
It could be the brakes if the pads are not lifting completely off the rotors.
Old Jun 15, 2011 | 10:59 PM
Jsedita74's Avatar
What would be the cause of this and is it a known issue?
Old Jun 16, 2011 | 06:39 AM
banjobill's Avatar
Hi,
Mine has a very similar noise, I've tried to locate it but to no avail, mine also makes a noise driving along up to 50mph difficult to explain the type of noise, wheel bearing sort of but not coming from the wheels?, but if accelerating hard it is quite, only when you ease your foot of and coming to a halt the noise is back, however sometimes when I take out of drive before I come to a stop the noise is not there, pointing to a gearbox problem.
The gearbox does change gear nice and smooth,
don't know if that helps any...
regards.
Old Jun 16, 2011 | 07:47 PM
hlgeorge's Avatar
Sticking and rust in the calipers. It can be an issue on any car, but not necessarily Jaguars in particular.
Old Jun 18, 2011 | 10:33 AM
Jsedita74's Avatar
bill my car exhibits this under abour 30 as its rolling . Ive tried putting into neutral to see if its the wheel bearings... but im not sure.... in my mind its the front wheel bearings but im not sure....
Old Jun 18, 2011 | 11:37 AM
Gus's Avatar
Gus
Try looking at your "U" joints
bamforp
Aug 14, 2024 05:36 PM
PMKimpton
Aug 3, 2019 08:22 PM
OkieTim
Sep 8, 2015 04:48 PM
giandanielxk8
Sep 6, 2015 07:21 PM
Numwen
Sep 6, 2015 12:30 AM
