Instructions on how to repair your adjustable pedals
Old Dec 29, 2023 | 08:00 PM
Jaroslav Záruba's Avatar
Originally Posted by Jaroslav Záruba
Yeah, I don't think the throttle pedal is supposed to be adjustable.
Wrong, wrong, wrong, wrong...
Old Jan 2, 2024 | 02:28 PM
Taking the washer off was hard as hell - when one can't fit in whole hand to grab that gear properly.
In the end I had to use tongue-and-groove pliers.
Also I ended up NOT putting the wavy washer back in.
At first I simply forgot to put it back, and the mechanism seemed to be working okay.
Then I noticed the abandoned wave washer laying on my desk so I put it in. And suddenly the mechanism visibly and audibly struggled.
Maybe it was because of this diameter being smaller on the new/brass gear:
Old Jan 3, 2024 | 06:15 AM
Wingrider's Avatar
Could be the end cap not being used to keep things sorted.
What did Chris have to say about shipping you another?
Old Jan 3, 2024 | 09:20 AM
Chris said he would gladly send one, adding it would be unnecessarily costly and slow tho, so instead he told me what kind of cap he uses: https://autofastenersandclips.com/pr...ner-205-height
While I couldn't find this exact kind of washer anywhere in Europe I am pretty sure I could use Starlock 6mm.
But I noticed the gear does not travel that far on the thread anyways.
While I was testing the gear for the first time, without the cap, I held the black plastic thing in place with my hand. When the mechanism stops (pedals furthest from the driver's seat) there was no push against my hand. And when I looked underneath the black piece there was still like 1 cm of thread spare.
In the end I put the original cap back in, even though I think it is useless.
I believe the wavy washer is more important, as it (IMO) prevents contact between the teeth and the black part.
So I want to find a washer (wavy or not) that actually fits the new gear. The original washer has the inner diameter too large, and I suspect it might be doing things as it dances around.
Old Jan 3, 2024 | 12:58 PM
Wingrider's Avatar
Look at the pictures, & use the stock one
Old Jan 3, 2024 | 03:13 PM
That's what I did, and as I said, the whole thing sounded like it was about to die. I suspect the issue is there's nothing to keep the wavy washer concentric with the gear.
Tomorrow I'll take the gear off and check if maybe it's not symmetrical, in which case I'll try to flip it around and use the wavy washer again.
Originally Posted by Boomer from Boston
Re steps 8 and 9, does the wave washer go under the steel cap? If not, what holds it in place?
I know this is 6 years later, but I was wondering the same... It appears that the only thing that holds the wavy washer in place is the black thing with the blue "w", i.e. the purpose of the wavy washer is to prevent direct contact (and thus grinding) between the gear and the black plastic piece when moving the pedals towards the driver.
Old Jan 3, 2024 | 04:03 PM
Wingrider's Avatar
The grease holds the washer in place till the cover is replaced
Old Mar 5, 2025 | 05:53 PM
  #28
Jaguar 1234's Avatar
Hi there, would anyone be able to tell me where I can buy the gear for the brake pedal height adjuster that is mentioned in this thread ?
Many Thanks
Old Mar 6, 2025 | 12:54 AM
https://www.facebook.com/people/Curless-Auto-Repair/100057655381863/?fref=tag&ref=embed_postthe forum doesn't seem to like the link above, so here in this post you should see more:
https://www.jaguarforums.com/forum/x...2/#post2770079
cheers
Old Mar 6, 2025 | 10:55 AM
  #30
Curless Auto's Avatar
Hello guys,
I am the guy that makes the gear you are looking for. We have them in stock. They cost $129 shipped in the US or plus shipping outside the USA. I can be reached at my shop by phone or by email.
616-988-1315
or
chris@curlessautorepair.com
quartetchiang
Sep 7, 2017 10:11 AM
42V8XKR
Apr 10, 2017 08:58 AM
stevepaa
Aug 31, 2014 08:44 AM
cbrica
Jul 6, 2014 05:30 AM
Selsoft
Jun 28, 2013 07:06 PM
