Intake Manifold Gasket - minimum effort?
Old Dec 2, 2024 | 09:12 PM
cooldood's Avatar
Default Intake Manifold Gasket - minimum effort?
LTFTs run up to around 10.
A smoke test produced a slight wisp that appears to be from the right hand side (RHS) intake manifold. Listening with a hose would support that same idea.
I had the intake off a year ago to do the valley hose, so have some memories of doing the job.
The question this time is, what is the minimum I would have to do to be able to just swap the gaskets for new ones (car is not currently here, so I cannot examine it).
EGR pipe/EGR would need disconnecting, engine cover brackets removed.
Would that be enough to lift the intake and remove the gaskets, or do I need to be draining coolant, unplugging a few dozen hoses, electrical connectors, etc.?
Old Dec 3, 2024 | 08:48 AM
wfooshee's Avatar
Gasket between the manifold and the head, or the several gaskets between the aluminum lower manifold and the plastic upper?
There is a lot of wiring to remove around the manifold, for sensors and injectors, then you unbolt it and slide it forward as far as the harnesses on the back will reach, at which time you can disconnect those and lift it up. basically, there is no "minimum effort;" it's a bit of a job.
If you got the cheap paper gaskets for the joint at the heads, those are junk. can't keep them lined up properly during installation, and something will get pinched or torn. You need the metal gaskets that have the tabs you bend up to clamp the bottom of the intake runners for alignment.
I haven't done the gaskets between the uppers and lowers, but when I ordered the gaskets for the lowers to the heads, it took three delivery/return cycles, from different sources, to actually get the metal gaskets that were illustrated on the sites I ordered from.
Old Dec 3, 2024 | 09:31 AM
xalty's Avatar
the green rubber seals fail
Old Dec 3, 2024 | 10:08 AM
cooldood's Avatar
I was thinking it was the lower manifold gasket. I used AJ85392 last time, metal, with tabs, but think they were aftermarket parts, not OEM. I also see AJ89062 appears to be a viable number for this gasket, not sure of the difference between them and both are recorded as fitting my car, even after entering the vin.
Maybe it is the uppers, I did not disturb nor replace those last time. I felt like the noise was coming from the lower portion, as was the smoke, but it was not very clear or definitive.
Old Dec 3, 2024 | 02:39 PM
Wingrider's Avatar
While you have the manifold off, i would replace the eight green internal gaskets.
Old Dec 6, 2024 | 09:47 AM
mbwillgrubs's Avatar
Do you have a suggestion for a reputable source for those intermediary gaskets (green)?
Old Dec 6, 2024 | 11:25 AM
Magooby's Avatar
I believe jagbits.com has them
partsgeek.com has them
I thought I saw them available at at least one of the local chain store auto parts stores (AutoZone, O’Reilleys, Advance Auto parts) but would have to search them to be certain.
if I recall correctly S N G Barratt didn’t have them but that’s one place I would bookmark for parts in general.
the biggest problem I’ve found is making certain you’re looking at the correct part. Read the description and fitment very well.
Old Dec 6, 2024 | 01:52 PM
Wingrider's Avatar
Look on ebay, here is what they look like;
jaguar xj8 4.2l upper intake manifold gasket (set of 8 seals) intake gasket
Brand New · MTC Parts
$119.00
or Best Offer
Free shipping
282 sold
Old Dec 22, 2024 | 03:10 PM
cooldood's Avatar
any opinions on the differences in the part number for the lower gaskets? AJ85392 versus AJ89062?
And best to fit them dry, or add some sealant to them?
Old Dec 22, 2024 | 04:44 PM
Wingrider's Avatar
Should have tabs that fold to hold them in place, no sealand needed
Old Dec 22, 2024 | 05:07 PM
cooldood's Avatar
Rewording this a little differently, if I cannot obtain new gaskets in time, okay to refit using some sealant?
Gaskets were new a year ago, it's been fine until recently, tabs are still visible sticking out from under the manifold, so assume gaskets are still in place.
Old Dec 22, 2024 | 05:40 PM
Wingrider's Avatar
Would clean & refit yours, if new was not available.
The plastic sound proofing edge could be pinched.
Hate the thought of using sealant on there
Might have to remove it someday.
Cleaning things up, could be a real issue
Old Dec 22, 2024 | 06:03 PM
cooldood's Avatar
Trying a smoke test, definitely coming from that area, but looking for all the world like it is the lower o rings on the injector.
Does that seem likely?
Old Dec 22, 2024 | 08:41 PM
cooldood's Avatar
New lower seals on the injectors cured the problem.
Steveh
Feb 24, 2025 08:27 AM
laurelez
Oct 12, 2024 09:57 AM
Nobeel Masri
Jun 15, 2022 05:45 PM
stevis05
Feb 17, 2009 05:30 PM
