I'm pretty sure the info is here but I have been unsuccessful in my search! I Have an air leak from the valve on the top of the strut. I have 2 questions.
1 How do you remove the valve. When I try to remove the 12mm air line connection the whole valve turns! I don't have room to try grip the valve. I have a feeling that I can simply grip and pull up popping the whole valve from the housing.
2 Is there an O Ring in there that leaks and if so where is the best place to buy a replacement.
abonano
close
- Join DateMar 2012
- LocationHazlet Township, NJ
Liked:1,435 Times in 1,073 Posts
There is an O ring on the bottom of that valve. If the tightness of that valve is compromised according to Arnott the strut needs to be replaced.Originally Posted by heligarret
I'm pretty sure the info is here but I have been unsuccessful in my search! I Have an air leak from the valve on the top of the strut. I have 2 questions.1 How do you remove the valve. When I try to remove the 12mm air line connection the whole valve turns! I don't have room to try grip the valve. I have a feeling that I can simply grip and pull up popping the whole valve from the housing.
There is no replacements available.
