Leaking Front Strut
Old Apr 26, 2015 | 06:57 PM
heligarret's Avatar
Default Leaking Front Strut
I'm pretty sure the info is here but I have been unsuccessful in my search! I Have an air leak from the valve on the top of the strut. I have 2 questions.
1 How do you remove the valve. When I try to remove the 12mm air line connection the whole valve turns! I don't have room to try grip the valve. I have a feeling that I can simply grip and pull up popping the whole valve from the housing.
2 Is there an O Ring in there that leaks and if so where is the best place to buy a replacement.
Old Apr 26, 2015 | 08:53 PM
abonano's Avatar
There is an O ring on the bottom of that valve. If the tightness of that valve is compromised according to Arnott the strut needs to be replaced.
There is no replacements available.
bamforp
Aug 14, 2024 05:36 PM
sogood
Sep 15, 2015 07:35 AM
34by151
Sep 6, 2015 05:14 PM
Xkr x100
Sep 6, 2015 08:50 AM
02jagstype
Sep 4, 2015 08:20 PM
