Lifting a 2005 vdp
Old May 17, 2023 | 12:12 PM
Estam's Avatar
Default Lifting a 2005 vdp
My mechanics garage has a hoist that has four figures that lift from the sills. I see where the lift jack points are, do the fingers have to be very close or is just close ok?
Many thanks for this...
Old May 17, 2023 | 12:14 PM
xalty's Avatar
with a rack use the pinch welds they have arrows pointing where you need to go.
with a floor jack you need to use the front frame rails next to the cat. rears you just sort of use the aluminum subframe sandwich point
Old May 17, 2023 | 12:42 PM
Estam's Avatar
I'll climb under and check where the arrows are for future ref. What is meant by' next to the cat?
Old May 18, 2023 | 08:28 PM
h2o2steam's Avatar
Cat....abbreviation for catalytic converter I would assume.
Old May 20, 2023 | 02:59 PM
Pete M's Avatar
Hi Estam
Here are the diagrams from the manual
Lifting with jacks
Lifting with a 2 post lift
Hope this helps
Pete M
al_roethlisberger
Nov 11, 2022 08:01 PM
Robbo D
Jan 15, 2022 03:58 AM
AndreasXJS
Feb 15, 2019 08:10 PM
saxandliz
16
Apr 10, 2017 09:26 AM
Goldlion
Dec 31, 2009 02:03 AM
