Memory seating
Can you give more detail ? Does it seem to accept a seat position then not go back to that when you press the memory button you set ? I had a problem with my previous X350, and was told to cycle the seat setting from max one way to max the other, then set the seat and enter to a memory button. Apparently the system can "forget" the seat setting ranges, so this cycling puts them back in. I assume it restores some reference settings.
al_roethlisberger
Apr 1, 2026 01:25 PM
Sheltoncar
May 12, 2017 01:38 PM
weisberg
Oct 20, 2014 07:20 PM
