Memory seating
Old Jun 23, 2017 | 08:46 PM
Michael Clark's Avatar
Default Memory seating
my power seats work, but not the memory
Old Jun 24, 2017 | 06:44 AM
Partick the Cat's Avatar
Are you sure that the car has seat memory fitted; do you have the three memory buttons on the driver's door ?
Old Jun 24, 2017 | 07:06 AM
Fraser Mitchell's Avatar
Can you give more detail ? Does it seem to accept a seat position then not go back to that when you press the memory button you set ? I had a problem with my previous X350, and was told to cycle the seat setting from max one way to max the other, then set the seat and enter to a memory button. Apparently the system can "forget" the seat setting ranges, so this cycling puts them back in. I assume it restores some reference settings.
Old Jun 24, 2017 | 09:16 AM
Yes it is equipped with memory, the mirrors and steering wheel work
al_roethlisberger
Apr 1, 2026 01:25 PM
Grant Francis
May 21, 2017 01:54 PM
Sheltoncar
May 12, 2017 01:38 PM
Chuck Schexnayder
May 31, 2015 08:44 PM
weisberg
Oct 20, 2014 07:20 PM
