My Jaguar will not stay running
Old Sep 22, 2017 | 08:09 PM
Nina Jo Clark's Avatar
Default My Jaguar will not stay running
Hello Nina here from Beebe Arkansas and I am new here.
I have a 2003 Jaguar XJ8. When I bought my jag would not start and I was told that it was the fuel pump. (Yes we got it extremely cheap). We checked the fuel pump and it was in pieces inside the gas tank. We replaced the fuel pump and the fuel filter. The car will not run. We have changed the relays in the trunk. The guy working on it says that he checked the inertia cut off switch. It is getting gas to the rail and it starts but it won't stay running.once the gas is used, it acts like something is telling it ok we don't need more gas. I have checked and replaced alot of stuff. What else can be causing this?
Thanks everyone,
Nina
Old Sep 23, 2017 | 02:17 PM
Fraser Mitchell's Avatar
Hi Nina
As your car is a 2003, the year a model change occurred, we need to know what model series it is. Jaguar have been calling their top saloon car the XJ since 1968 ! My XJ6 car is the 7th iteration, and made of aluminium. Your car could be the X308 series, made of steel, with a 4.0 litre V8 engine, or the X350, made of aluminium with a 4.2 litre V8. So what is it ? If you don't know, post a photo on here.
As regards your fault, normally with the X350 series cars, the engine control unit can detect things are wrong and post a fault code. Do you get any fault lights or messages ?
Old Sep 23, 2017 | 05:30 PM
Default 2003 Jag won't stay running
Thank you I am new on here and I am learning what I should do. I will put pictures on here as well as much description as I can. I will locate all the stuff tonite.
Nina
Old Sep 24, 2017 | 09:14 AM
JagV8's Avatar
The last 6 of the VIN will probably reveal all.
Old Sep 24, 2017 | 01:26 PM
The last 6 of the VIN # F58920. Once I figure out how to post pictures I will
Nina
Old Sep 25, 2017 | 01:27 AM
JagV8's Avatar
I have that as an X308 (sometimes called X338 if LWB - long wheel base) and in that case this isn't the right forum.
You're near the end of the VIN for an X308.
Old Sep 25, 2017 | 10:29 AM
Default 2003 Jag XJ8 V8
If this is the right forum, what forum should should I be on? Here is pic of my Jag
Old May 5, 2023 | 03:20 PM
kbusby1989's Avatar
hey I have literally the exact same issue and details I bout cheap was told itvneeded fuel pump and when i check it was taken apart so my question is if you ever figured out what was wrong with yours
Old May 6, 2023 | 12:37 PM
Thomas-S.'s Avatar
As JagV8 stated you would need the X308 forum:
https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/
Best regards,
Thomas
Old May 6, 2023 | 01:41 PM
kbusby1989's Avatar
Best regards,
Thomas
I wasn't talking to you
Old May 6, 2023 | 01:57 PM
Thomas-S.'s Avatar
I was replying to Nina and trying to be helpful. If there was a misunderstanding, there i no need to get rude,
Old May 6, 2023 | 08:48 PM
Big Koshka's Avatar
@kbusby1989 OK, Then, who exactly are you talking to?
May be you should put a list of people you do not care to hear from, so we all know. I figure my handle will be on that list
Old May 6, 2023 | 08:50 PM
Don B's Avatar
Dear kbusby1989,
Welcome to the Jaguar Forums!
The last we have heard from Nina Jo Clark in this thread was in 2017, so rather than telling another member, "I wasn't talkiing to you," perhaps you would do well to consider the advice of any member who will kindly respond to you at all in 2023.
Please start your journey here by visiting the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you proper welcome.
Second, please read all the information at this link:
https://www.jaguarforums.com/forum/n...-up%2A-241802/
Then, and only then, please reply to this thread and tell us the year, model and engine displacement of your Jaguar so we can help you determine which forum is correct for your car.
Cheers,
Don
Backhertz
Sep 17, 2017 01:01 PM
ahunt4
Jan 19, 2015 11:57 PM
HeatherB
XJ40 ( XJ81 )
Jan 8, 2012 02:22 PM
Spitfire
Jun 25, 2010 08:38 AM
porschegonzo
Jun 7, 2008 04:14 AM
