Need help with the ACM power harness
Old May 11, 2015 | 12:54 PM
H20boy's Avatar
Default Need help with the ACM power harness
This plea is going out to anyone with the ACM installed in their s-type, x-type, or XJ.
The audio connectivity module kit comes with a intermediate connector wiring harness at the rear of the head unit that gives power and 'wake-up' signals to the ACM via an offspring pigtail. See the below pic.
Now, here's where I need your help. I'm lacking the harness. I am asking somebody to physically identify the wires on that harness that this little pigtail connector shares, or to the pins on the head unit that correspond, and to which order those apply to the 4-pin connector.
Pics would be FANTASTIC, and you'd have my utmost appreciation and in your debt. Thanks guys!
Old May 12, 2015 | 09:09 AM
magmedia's Avatar
I may be pulling my acm soon. Will be happy to share pics and info following the removal.
Should be a week or so.
-mag
Old May 12, 2015 | 08:15 PM
H20boy's Avatar
Thanks mag, so far, you're all the help I've got.
Old May 13, 2015 | 01:15 AM
34by151's Avatar
Im not planning on taking the head unit out soon but If I do ill get the info for you
34by151
Old May 13, 2015 | 12:28 PM
anindyam's Avatar
Mag, et al - I'd be interested in this info as well.
Old May 17, 2015 | 09:27 AM
magmedia's Avatar
Pulled the acm today.
Please see some photos of the harness. Looks like red black and purple on the head unit harness to the ACM box.
Thanks-
Mag
Attached Thumbnails Need help with the ACM power harness-image-3473123723.jpg
Old May 17, 2015 | 09:28 AM
magmedia's Avatar
Uploading from app...
Attached Thumbnails Need help with the ACM power harness-image-598600565.jpg   Need help with the ACM power harness-image-1438720329.jpg   Need help with the ACM power harness-image-931904636.jpg   Need help with the ACM power harness-image-2737419814.jpg   Need help with the ACM power harness-image-3051938881.jpg
Old May 18, 2015 | 03:01 AM
veffremov's Avatar
Red is 12V battery permanent power; Black is ground. The purple is the D2B "Wake Up" signal.
Old May 18, 2015 | 03:17 PM
cergun's Avatar
mag,
Thank you so much for the info.
Can you also send the ACM end of the connector?
I ordered the same molex connector (hopefully) but I don't know which pin goes to where on the ACM connector.
Matt,
thank you so much for the help on getting the information.
Old May 18, 2015 | 05:43 PM
magmedia's Avatar
Black top left
Red bottom left
Purple top right
With clip on top, facing 'into' connector
Mag
Attached Thumbnails Need help with the ACM power harness-image-1686863530.jpg   Need help with the ACM power harness-image-3081652131.jpg   Need help with the ACM power harness-image-1212652566.jpg   Need help with the ACM power harness-image-2685875191.jpg
Old May 18, 2015 | 10:46 PM
cergun's Avatar
Mag, once again thank you so much! this will help tremendously with the harness build.
Old May 19, 2015 | 03:02 PM
H20boy's Avatar
Mag, great information, and thank you for taking the time to document it!
Old May 19, 2015 | 06:53 PM
magmedia's Avatar
No troubles, glad to help.
-mag
Majik Lasers
Aug 2, 2024 01:49 AM
2001 White XJ8
Feb 25, 2021 05:02 PM
perezal
Dec 24, 2015 04:56 PM
flyrr100
Sep 18, 2015 06:31 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
