need help with this code from pcm
am currently working on jaguar xj 350 2009 model. the gear box fault light is permanently on and scanner cant see tcm .the fault codes are as follows, pcm - u0101-00, ABS - U0402-00 , PBM - U 0101-00 and ICM - U 2522. I have checked and clean all the earth signal points and have even tested the can signals .
i just want to know where is the tcm located on this model .
thanks House.
thanks House.
DE,
Before anything else, check battery voltage AND wheel sensors.
(Look at fault history. If it started with wheel sensor, fix and clear first. Car driven with bad sensor can arrive at this state. TCM is separate module)
ColinBarr
Jul 10, 2018 08:43 AM
bballarin
Jul 6, 2012 02:18 AM
