need help with this code from pcm
Old Oct 15, 2022 | 09:15 AM
DE BROWN's Avatar
Default need help with this code from pcm
am currently working on jaguar xj 350 2009 model. the gear box fault light is permanently on and scanner cant see tcm .the fault codes are as follows, pcm - u0101-00, ABS - U0402-00 , PBM - U 0101-00 and ICM - U 2522. I have checked and clean all the earth signal points and have even tested the can signals .
i just want to know where is the tcm located on this model .
thanks House.
Old Oct 15, 2022 | 11:37 AM
motorcarman's Avatar
Mechatronics, part of the valve body inside the gearbox.
Old Oct 24, 2022 | 08:33 AM
OldKarz's Avatar
Make sure that the connector is not full of transmission fluid due to the seal leaking.
Old Oct 24, 2022 | 08:48 AM
hisport's Avatar
DE,
Before anything else, check battery voltage AND wheel sensors.
(Look at fault history. If it started with wheel sensor, fix and clear first. Car driven with bad sensor can arrive at this state. TCM is separate module)
Old Oct 24, 2022 | 08:54 AM
OldKarz's Avatar
As Motorcarman said the TCM is inside the transmission.
1935Pontiac
Jul 24, 2022 03:40 PM
ColinBarr
Jul 10, 2018 08:43 AM
reedster
XJ40 ( XJ81 )
Jul 28, 2016 10:22 PM
DKurtti
May 24, 2014 09:14 AM
bballarin
Jul 6, 2012 02:18 AM
