Need to replace the audio amp module
Old Aug 9, 2021 | 01:48 PM
mguzman's Avatar
Default Need to replace the audio amp module
Need to replace the audio amp module in a 2008 Vanden Plas. The dealer says it's p/n: C2C29367, but it is no longer produced or available.
Is it necessary to use this exact module? Seems to me that there would be better and newer generic ones available that could work.
Does anyone have any experience with this?
Thanks.
Old Aug 10, 2021 | 08:41 AM
wfooshee's Avatar
There won't be a generic, as the inputs are all optical. The line-level and control signals from the head unit and the CD Changer are carried on a DB2 fiber-optic network which has very limited, if any, aftermarket support. Other cars of the time period use MOST optical systems, which have wide aftermarket support.
A used amp from eBay or somewhere like that is your only hope, I think.
Old Aug 10, 2021 | 11:00 AM
mguzman's Avatar
Thumbs up
Thanks for the reply.
Old Aug 13, 2021 | 03:01 PM
JoeDredd's Avatar
I have recently had to replace my amp due to water ingress through body panel seams. It looked ok until I took it out and opened it up and found it wasn't OK at all.
2859bar
Jan 6, 2021 06:06 PM
StevieG1234
Jan 11, 2020 08:36 AM
Jyuu
Oct 8, 2019 01:43 AM
ddsand
Jun 10, 2019 01:21 PM
sweatyfox
Jan 19, 2017 01:10 PM
