New battery help
Old May 27, 2016 | 02:49 AM
fingers's Avatar
Default New battery help
2003 x350 petrol.
I need to fit a new battery, will I need to put a code in for the radio and if so what is the precedure for this. Also do I have to reset anything when it's done. Thought I'd do a hard reset whilst I'm at it so would like to know the correct procedure for this too.
Many thanks
Old May 27, 2016 | 04:02 AM
jimbov8's Avatar
You will need the code for the radio. When you switch on it will ask you for the code, simply press in the 4 digit code and all is well. Any memory functions you have will also need to be reset.
Other than that, nothing to it.
Old May 27, 2016 | 05:28 AM
Partick the Cat's Avatar
You may loose your milage and mpg readings for Trip A and Trip B, so note them down beforehand if they are important to you. However, they do take a minute or two to go and as it happens I didn't loose mine when I changed my battery, but I can't remember now whether the radio needed the code or not.
Old May 27, 2016 | 09:23 AM
grantorino62's Avatar
When I switched batteries on my 05, I didn't need to reset the radio code. I did loose all the radio station memories and tripmeter readings. If you do loose the radio, do you have the code in your owners manual? If not, I believe a dealer must get it for you. On my Mercedes they needed the serial number on the radio itself to get it.
Old May 27, 2016 | 11:04 AM
Sean W's Avatar
U.S. vehicles don't require a code. European vehicles do.
dennyhle
May 25, 2016 09:21 PM
NathanDD6
May 8, 2016 02:11 PM
avern1
May 5, 2016 01:49 PM
jeffn
Apr 30, 2016 10:18 PM
