No power to throttle body
Old Sep 22, 2022 | 04:00 PM
viper1996's Avatar
Default No power to throttle body
Hi does anybody know what the 2 wires are on the 2 pin connector to the throttle body is one ground and the other 12 V? I just don't seem to be getting any power there and don't know why
Old Sep 22, 2022 | 07:04 PM
h2o2steam's Avatar
I doubt either wire is a rigid earth, as the schematic has them both listed as B+ to drive motor.
TB drive motor will likely be driven in both directions (forcing open and closed), so both lines are likely to be able to be positive or negative with respect to each other depending on the throttle movement direction required.
Check your inertia switch hasn't tripped.
Then check F12 and F17 (both in the front power distribution fuse box).
Old Sep 23, 2022 | 12:27 PM
viper1996's Avatar
Awesome I'll take a look! Thanks
SpartanX
Sep 21, 2020 09:50 AM
Crandell
Mar 21, 2019 11:44 PM
fredd60
Mar 10, 2019 09:01 PM
dbrilla
Dec 2, 2018 12:23 PM
wack61
Oct 25, 2011 09:42 AM
