No Speakers in Dash
Old Sep 27, 2021 | 03:58 PM
silversurfer1221's Avatar
Default No Speakers in Dash
Hello. I have a 2006 Jaguar XJ8. Recently, my dash speaker grilles became deformed and cracked due to age and the sun/heat. I've ordered new ones (lucky to have found them), but after removing the old grilles to repair them (until the new ones arrive), I see that there are no speakers here at all. The area is quite clean and it looks like there had never been any. Was this a thing (to have no speakers there)? Were there certain audio packages that had them and other, lesser packages, that did not? Or is it more likely that they were removed some time in the distant past? The sound system in the car sounds nice as is, but I'm thinking about getting some speakers to put there. Is it difficult to install them (mainly getting to and connecting to the wires)?
Old Sep 27, 2021 | 06:46 PM
xalty's Avatar
i worked on an 04 xj8 that had no speakers there either
Old Sep 27, 2021 | 06:47 PM
So, it may have been an "option" ... a lesser audio package that just didn't include them?
Old Sep 27, 2021 | 06:57 PM
Cambo's Avatar
Only the Alpine system has the speakers in the dash. The base audio doesn't have them, and they are not wired up either.
Old Sep 27, 2021 | 06:58 PM
Thanks. I wondered about that. So, it would be a PITA to try to put speakers there, then, I take it ...
Old Sep 27, 2021 | 08:31 PM
J.A.G.'s Avatar
Default I have a 2005 XJ8 L 2005 No speakers there.
Since I already installed an aftermarket stereo I installed twitters in there. It was really easy to wire up the driver side, but the one in the passenger side was really difficult. I removed a lot of things that are not even close to be the way to go just to find out it was not the way. After a few scratches on my hand I was able to do it.
So if you're planning on doing some aftermarket things with your stereo, that's a good place for twitters, even if they are not pointing to the listeners, the inclined position of the windshield will do the job.
Old May 15, 2022 | 11:25 PM
pkoko's Avatar
I am soon going to be doing the same thing. Can you elaborate on that? I will also send a PM. Thanks
asjdhsajhdfj
Aug 8, 2021 06:57 PM
DougXK8
Jun 20, 2021 08:16 AM
Zarro
Sep 24, 2015 08:34 PM
hafferf
Sep 21, 2010 11:58 AM
