Noise starts at exactly at 36-37 mph
Old Nov 19, 2012 | 02:49 PM
03Xtype's Avatar
Default Noise starts at exactly 36-37 mph "FIXED"
It's like clock work if you want to make the noise start, after it starts it won't go away unless you come to a full stop.
It sounds like a scraping or scratching metal on metal noise. But maybe it's a loud air suspension leak?
The 2004 xj8 has new front brakes and I bent the brake dust shields away from the rotors
Any ideas what it could be?
Old Nov 19, 2012 | 07:38 PM
N9921x's Avatar
Smile 36 mph metal scraping noise
Did it do it before you renewed the brakes?
If not, then maybe just maybe something went wrong on the brake parts.
Misassembled caliper to pad springs or wrong pads would be my guess.
Clean and lube the slides?
Easy to check and fix, I think.
Good luck.
Old Nov 19, 2012 | 10:00 PM
03Xtype's Avatar
The noise has been around since I bought the car
Old Nov 19, 2012 | 11:13 PM
N9921x's Avatar
Could it be a wheel bearing?
Old Nov 20, 2012 | 12:34 AM
meirion1's Avatar
Your ford engine is pretty bulletproof but the Jockey pulley can fail.
Old Feb 11, 2013 | 08:35 PM
03Xtype's Avatar
The noise is still around, I think I have it narrowed down to the left front. I lifted the back end up and had the wheels spinning at 60 mph with no noise.
I'm not having any other symptoms of a wheel bearing going out but I think I will look in to it.
Old Feb 15, 2013 | 01:07 PM
03Xtype's Avatar
I was finally able to simulate the noise by running the vehicle with the wheels off the ground.
Here is the cause of the noise. It is amazing how loud and deceiving a rattling piece of plastic can be.
Attached Thumbnails Noise starts at exactly at 36-37 mph-p2120162_zps0fe2c20c.jpg   Noise starts at exactly at 36-37 mph-p2120163_zps0663235f.jpg
Old Feb 15, 2013 | 02:49 PM
N9921x's Avatar
Smile Congrats on resolution
I love it when a thread comes to conclusion and the final results are posted.
Good honesty.
Glad you found the problem.
Take care.
PMKimpton
Aug 3, 2019 08:22 PM
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
robiwhan
Sep 4, 2015 10:43 AM
XFR_Gold
Sep 2, 2015 12:24 PM
innzane
Sep 2, 2015 10:08 AM
