O/S rear indicator intermittent
Old Mar 6, 2021 | 06:00 AM
Filmscoreking's Avatar
Default O/S rear indicator intermittent
Hi all,
The O/S rear indicator on my XJR is intermittent. Weirdly ever since I replaced the bulb. I know it’s not the bulb at fault as I’ve had it checked by various technicians. They tell me it’s probably a wiring fault with whatever controls it. Can anyone point me to what I need to look at/potentially replace? I draw the line at fiddling with electrics but if it’s simple enough then I can at least take a look!
thanks
Dan
Old Mar 7, 2021 | 06:57 PM
kg74's Avatar
It could be "the Stalker". Look up the latest posts on failed turn signal stalks. There are a rash of them lately. A failed turn signal stalk causes all sorts of lighting issues.
Old Mar 8, 2021 | 02:06 AM
thank you! I’ll check that out
KC02
Dec 8, 2019 10:08 PM
nghisus
Mar 17, 2019 11:05 AM
TreVoRTasmin
Jan 25, 2018 07:11 AM
BW_Hunter
Jul 29, 2017 07:16 PM
