Can't find a bulb chart with the rear (red) side marker bulb
Old Jan 15, 2018 | 11:37 AM
TreVoRTasmin's Avatar
Default Can't find a bulb chart with the rear (red) side marker bulb
Mine is burned out and my wife has the car so I can't just pull it and take it to the store, does anybody know what the bulb number would be for a standard Phillips or Sylvania bulb? Both list the front marker but not the rear. I'm guessing it is the same but it is darn cold out to be try to replace it and be wrong.
Old Jan 15, 2018 | 12:37 PM
Jon89's Avatar
For my wife's 2006 XK8, that particular bulb is listed as a 12V 5W capless long life bulb....
If you find that the bulb is not so much burned out as it is rusted away due to water inside the lamp assembly, Welsh Enterprises sells new rear side marker lamp assemblies complete with bulbs for a very reasonable price. I paid about $15 each back in October 2015. The lamp assemblies are prone to allowing water in as the years pass by....
Old Jan 15, 2018 | 01:10 PM
woox4's Avatar
Same as the front - W5W or 501 type bulb.
Old Jan 17, 2018 | 11:01 PM
bcprice36's Avatar
Both the Front Marker Bulb and Rear are the same....The Lens is where the color comes from....It's a little wedge bulb Silver Star (Sylvania) #2825....It is a clear Bulb.....Also the same for the Parking Light.....and probably several more like License Plate........
Billy Clyde in Houston
Old Jan 25, 2018 | 12:18 AM
Flipr78's Avatar
Do you stick the blade of a putty knife underneath the lens to pop it off?
Old Jan 25, 2018 | 07:11 AM
Jon89's Avatar
Reach underneath the side of the rear bumper and carefully push the lens assembly out with your fingers. There are a couple of metal spring clips that hold it in place. Take a small flashlight under there, have a look at the back of the lens assembly, and you will quickly understand the process....
xjfourty
Dec 12, 2017 05:21 PM
gbmtkj
Dec 29, 2014 09:13 AM
esloser
Sep 1, 2013 08:32 AM
4bizonly
Nov 26, 2011 11:17 AM
rogerdodger
Dec 1, 2010 04:15 PM
