oil pan gasket confusion
Old Jan 22, 2021 | 03:05 PM
aceler8's Avatar
Default oil pan gasket confusion
Hello all, i'm fixing an oil leak from the pan gasket. I dropped the pan today and went to install the rubber gasket ( Mahle OS32287 ). Problem is, when i inserted the gasket along the bottom of housing there is about a 1" excess of gasket. I removed and tried again, but it appears too long. I searched online and this board and folks have used this same gasket part number with success. I'm confused... is there something i'm forgetting or did they change pans during a model year? I have a 2005 XJR.
here is the one i purchased:
oil pan gasket on rockauto
Old Jan 22, 2021 | 04:42 PM
jackra_1's Avatar
I had the exact same issue.
Old Jan 22, 2021 | 05:46 PM
abonano's Avatar
2004 XJR - used this gasket.
No issues. Make sure the surface is as clean as possible. Should only go in one way.
No gap after install.
Make sure your not installing upside down.
Old Jan 23, 2021 | 07:38 AM
aceler8's Avatar
jackra...do you recall which gasket you did use for proper fitment?
Old Jan 23, 2021 | 07:39 AM
aceler8's Avatar
i laid out both gaskets and the Mahle is definitely longer..very odd.
Old Jan 23, 2021 | 07:48 AM
jackra_1's Avatar
I do not I ordered at least 3 different ones before I got one that was the correct size.
Old Jan 23, 2021 | 08:11 AM
aceler8's Avatar
i'm searching online and i find differences...when i go to Cary Jaguar's site they have a different gasket number, but almost all other sites show the gasket i used. I'm guessing they used a different pan on some models. Maybe you and I ended up with non supercharger engine oil pans. Very odd and i'm gonna order a few like you did and figure it out in the driveway. Probably cheaper then the dealership.
Old Jan 23, 2021 | 08:40 AM
jackra_1's Avatar
It cost me quite a bit of time!
Old Jan 23, 2021 | 08:46 AM
aceler8's Avatar
I ordered part number NCA-1730AD which is what Cary Jaguar suggested. Hope it works this time...i'll update this thread on the results.
Old Dec 2, 2023 | 04:45 PM
Kadeer_xj6's Avatar
Curious if this one fit, I have the same problem the replacements are longer than original.
johnellison117
Apr 24, 2018 12:10 PM
05S-Stype
Jun 25, 2016 04:11 AM
Lagonia
Jan 4, 2015 12:41 PM
FloriVol
Oct 23, 2011 01:36 PM
