p0102 Solved after three longs days
Old Sep 18, 2016 | 05:55 PM
Evan Trinh's Avatar
Default p0102 Solved after three long days
My 09 X358 threw the code p0102. I scanned it and it said low voltage on the maf. Checked for leaks (none). I then removed the sensor and swapped another. I reset the code and this is what happened. The first start up after code is reset car runs great. I can drive 500 miles and the light wont trigger. Shut her off. On the second cycle the code pops. Car runs perfect still.
So I again reset the code. This time I also reset the ECU. Start her up no codes. Now I went in deeper with my scanner and found the p0102 pending.
Second cycle and boom it pops again. I went back to the auto parts store and showed them. I know if the sensor is not OEM it can confuse the Air readings. I then traded that sensor for one with a lifetime warranty. DL-3000 I believe it was. I screwed it in, scanned, no codes. And this time no pending p0102.
I knew the issue was fixed 100%
Im so happy my car is back to normal. It was very frustrating. I kept telling myself the car is not smarter than me. I will figure it out. I now know how sensitive these sensors can be and a slight difference the way it was designed will cause problems. Hopefully this info is helpful to others. The aftermarket MAF DL-3000 is a perfect match for this vehicle.
Anyhow its a beautiful day in Vegas
Old Sep 18, 2016 | 11:20 PM
06-XJR's Avatar
How did you reset the ECU? Nice car by the way.
https://www.obd-codes.com/p0102
Old Sep 19, 2016 | 01:03 AM
JagV8's Avatar
Along with many others, that code needs 2 trips to set. (Mandated by US and other laws, and documented by Jaguar and others.) So, at least you were seeing what should occur and hopefully it's now fixed.
Old Sep 19, 2016 | 01:37 AM
Evan Trinh's Avatar
I cleared codes first with scanner and then I just disconnected the battery
Old Sep 19, 2016 | 01:42 AM
Evan Trinh's Avatar
Thanks for info buddy. Actually to think of it I could of asked members here and probably wouldn't have had to struggle with it for three days. I'm glad I was able to figured it out eventually
Old Sep 19, 2016 | 04:20 PM
JagV8's Avatar
A fix is a fix
Old Sep 19, 2016 | 08:39 PM
ryejag's Avatar
Beautiful car. Did you ever find a problem to create the codes? I needed to replace one small oring on one the small plastic tubes
RyeJag
Old Sep 20, 2016 | 03:42 PM
Evan Trinh's Avatar
RyeJag
Yes in conclusion it was the MAF sensor. I guess the one I got originally was defected for being brand new. Swap it out with the different brand (DL-3000) and all is well again.
I know how important those O rings are. I actually changed all O rings within the TB and intake hoses, added one to oil dipstick as well
jakesdad
19
Sep 9, 2016 04:24 AM
Harry Peter Rose
Aug 29, 2016 06:28 PM
RobinGa
Aug 29, 2016 11:15 AM
carzaddict
Aug 28, 2016 10:05 PM
crvols
Aug 27, 2016 01:05 PM
