P0128/u0132/p2601
Old Oct 15, 2016 | 07:40 PM
Bobcameron's Avatar
Default P0128/u0132/p2601
I'm receiving the following codes after a 2 hour highway trip:
----Pending Trouble Codes Scan Report----
3 Pending Trouble Codes Trouble Codes:
1. P0128
Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
2. U0132
Lost Communication With Suspension Control Module "A"
3. P2601
Coolant Pump "A" Control Circuit Performance/Stuck Off
Does anybody have any ideas what could be causing these three errors? Do you know if they may be related?
Old Oct 15, 2016 | 09:22 PM
06-XJR's Avatar
P0128 - https://www.obd-codes.com/p0128 - coolant / fan / sensor / thermostat
U0132 - wiring?
P2601 - wiring / circuit issue.
I've heard on this forum before that body grounds can cause multiple issues... hmmm...
Old Oct 15, 2016 | 10:18 PM
Don B's Avatar
Hi Bob,
First of all, can you please tell us the year, model and engine of your Jag? That will help others provide the most accurate replies.
Assuming your car is an X350, you can download the full Diagnostic Trouble Code Summaries manual at this link:
https://www.google.com/url?sa=t&rct=...03388427,d.cWw
As 06-XJR mentioned, electrical faults such as low battery voltage, corroded ground points or electrical connectors can cause spurious fault codes. If it were my car, I would clear the codes and see which, if any, recur.
Regarding the codes you pulled, note that Jaguar's definitions and possible causes often vary from the generic definitions at OBDII code websites, and not all codes were implemented by Jaguar. Also, generic OBDII scanners sometimes misinterpret Jaguar codes.
Here are the Jaguar definitions and suggested causes, per the X350 DTC Summaries manual:
P0128: Coolant thermostat range / performance.
Possible causes include:
Contaminated coolant
Engine coolant thermostat failure
ECT Sensor failure (ECT Sensor DTC(s) also flagged)
U0132: Not found in manual, possibly not implemented by Jaguar. (reconfirm the DTC).
P2601: Not found in manual, possibly not implemented by Jaguar. (reconfirm the DTC).
Cheers,
Don
Old Oct 16, 2016 | 02:42 AM
woox4's Avatar
You codes look OK as my 2005 workshop manual gives the same causes:
Does your temperature gauge decrease below the middle line when going downhill or no load? If so, your thermostat seal has failed and could cause a P0128.
The other two, rightly or wrongly I usually reset them and see if they reoccur.
Old Oct 16, 2016 | 11:55 AM
JagV8's Avatar
I have P2601 as the SC coolant pump, flagged because IAT2 is hotter than it should be.
Old Oct 16, 2016 | 09:51 PM
Don B's Avatar
Chris,
Thanks for checking the Workshop Manual. For some reason those two codes are not in the DTC Summaries manual.
Cheers,
Don
JB73
33
Sep 11, 2020 07:06 PM
BobRoy
Mar 18, 2017 10:48 AM
xk8newbie
Nov 21, 2016 06:32 PM
Brian Miller
Sep 20, 2016 06:05 PM
Philkitter
Sep 19, 2016 06:37 AM
