P0171 Code Resolved
Old Oct 16, 2023 | 02:52 PM
rentzoo's Avatar
Default p0171 troubleshoot what first exhaust smell
If I do smell exhaust from the upper driver side engine bay, where would you trouble shoot first? the joint between the manifold pipe down to the Cat Converter connection? Put a spacer there?
it's a P0171 bank 1 lean that stayed on and restricted performance goes away at higher speed. Thanks!
03 S type R
picture from my mechanic
Old Oct 17, 2023 | 07:31 AM
ryejag's Avatar
My 2004 XJR has been troublesome area with lean fuel trims. The MAP sensor is a critical part of the fuel trim . My car runs best and code free with a DENSO mb197400-3021 sensor. I have replaced numerous parts to fix the lean code, including hoses, o rings, EGR valve, Throttle body and done fuel injector cleaning.
RyeJag
Old Oct 17, 2023 | 03:37 PM
JagV8's Avatar
RyeJag
What are the fuel trims (measured as usual, at idle & about 2500rpm)?
Abe Mirza
Jul 19, 2023 08:53 AM
jry
Jun 2, 2022 12:30 PM
JagXK82001
Jul 13, 2017 04:38 PM
Wingrider
30
May 26, 2017 07:04 PM
noterman
Aug 18, 2016 08:11 PM
