Passenger Mirror Dip Inoperative
Old Aug 18, 2017 | 07:56 AM
reberle's Avatar
Default Passenger Mirror Dip Inoperative
2004 XJ8 Base Passenger side mirror dip when placed in reverse stopped operating few weeks ago. Noticed after fuel pump was replaced as last major work in which battery was disconnected. Is the mirror dip operation a program or memory fix. Is it a DIY easy fix ? Great feature - but not worth dealer fix. Thanks
Old Aug 18, 2017 | 09:46 AM
Wingrider's Avatar
Mine still dips, but it does not come all the way back up, when shifted out of reverse. Will eventually fix it myself, but at the moment i don't know how.
Old Aug 18, 2017 | 10:23 AM
Boomer from Boston's Avatar
I never knew these mirrors were supposed to do that ! Don't know if mine does or not. What is the point of this "feature" ?
Old Aug 18, 2017 | 03:25 PM
motorcarman's Avatar
It is a 'configurable feature' in the DEALER OPTIONS section 'setup and configuration' of WDS/IDS.
You can look at the configuration to see if it is ENABLED or DISABLED.
It might have inadvertently been changed or the position sensors in the mirror have failed??
bob
Old Aug 18, 2017 | 06:10 PM
meirion1's Avatar
A very useful feature-you can see the kerb when reverse parking.
Old Aug 18, 2017 | 07:19 PM
Wingrider's Avatar
Any simple way to fix or disable?
Old Aug 22, 2017 | 06:53 AM
reberle's Avatar
Helps assist in looking at the curb /wheel to concrete relationship when backing up while parking - neat feature !
Old Aug 22, 2017 | 07:00 AM
reberle's Avatar
Thanks - can WDS/IDS be accessed via the nav. screen vehicle settings at some sub level somewhere? - I do not see any means of programing or enabling on own. Does it require mechanic /dealer enable ?
Old Aug 22, 2017 | 10:07 PM
Don B's Avatar
WDS/IDS/SDD are abbreviations for dealer-level diagnostic systems (see the link to a list of Jaguar acronyms & abbreviations in my signature line). There is no on-board means of reprogramming the mirrors, so you will have to visit a Jaguar dealer or an independent shop with the necessary system.
Here's the page from the 2004 Owner's Manual / Driver's Handbook - see the copy in the lower right corner:
Cheers,
Don
Old Aug 23, 2017 | 03:24 AM
rtcosic's Avatar
Don
If I read that correctly then the driver's mirror can be configured to dip as well.
That would be very useful; I will try that any time I have to visit my Indy again.
Old Aug 23, 2017 | 09:45 AM
When I worked at the dealer years ago I told the salesman on the showroom floor to have the customer come into the repair shop to setup all the features that they wanted.
I told them they get one shot at it around the PDI setup for no charge.
Any items that they wanted changed at a later date would be charged to the customer or sales dept.
I let the customer see the list and configure the features desired.
bob
File Type: pdf
Old Aug 24, 2017 | 06:28 PM
Don B's Avatar
Hi rtcosic,
Just for the record, I have SDD so I've tried having both the driver- and passenger-side mirrors dip, and personally I prefer to have only the passenger side dip.
The dipping passenger mirror gives you a good view of curbs and such, which is very useful. But it's far less common to park with curbs on the driver side, so I've found that I prefer to retain the normal angle of view to help detect vehicles, pedestrians and other taller obstructions.
Cheers,
Don
05S-Stype
Nov 5, 2016 01:28 AM
Oct 8, 2016 05:04 PM
andersen06
Aug 30, 2016 06:20 PM
JimC64
Detailing / Car care
Jun 25, 2012 01:42 AM
XType750
Jan 31, 2007 07:58 PM
