power steering not working.
first thing I would do is disconnect the tie rods and see if you get your PS back.
It always helps others when it's time for us to change out ours, what sort of issues can we expect to encounter?
I don't understand, please help me out here; Why cheap tie rod cause PS not work? Did you DIY or have the garage do it for you? If it cheap by quality it might break premature, but the PS should still work, if it build not same size you can not install it to your car, if it either too short or too long you might can not have right alignment but it still would not make PS not work.
Hi All:
I have a possible explanation for how changing outer tie rods and new tires fixed the issue with the power steering. The tie rods I installed were from O'reillys auto parts. I installed them myself and no alignment issues. When I removed them one was shot after less than 3,000 miles. I can only surmise that it was binding and hindering the ability of the power steering. My tires had no outwardly visible unusual wear but I think that wear, causing an unusual cant may have been a contributing factor.
Yep, close enough for government work as they say.
