power steering return hose
Old Nov 2, 2023 | 12:07 PM
mhamilton's Avatar
Default power steering return hose
Anyone know the size/type of the p/s return hose? Jag only sells it as part of the complete cooler assembly (typical), I just want to replace the hose between the rack and cooler with standard hose. I assume it's a standard type of hydraulic hose?
Edit: apparently at one time Jag did sell just the rack-to-cooler return hose as C2C35056, but this is NLA. Would be easier (and cheaper) to rebuild myself than source OEM.
Old Nov 2, 2023 | 03:17 PM
Wingrider's Avatar
Taking it off, to see what the size is, might be your next step.
Old Nov 2, 2023 | 04:11 PM
FreeWifi's Avatar
Original part is discontinued but Parts Geek or
Amazon Amazon
URO brand. Parts Geek also carries Genuine brand at twice the price. Also on eBay.
Old Nov 3, 2023 | 07:52 AM
mhamilton's Avatar
Thanks--
Yes I also saw that URO makes a replacement, but I've heard they're the Dorman of Euro car parts.
Definitely, I will eventually just take the old hose off and measure, but was hoping someone would know so I could order stock hose and do the drain/refill once. I can't imagine I'm the first one replacing this!
Old Nov 5, 2023 | 07:03 AM
Wingrider's Avatar
The rubber portion of the transmission to the radiator lines is 1/2 ".
The P S may be the same size, a quick measurment of the lines will tell.
worzella
Jul 5, 2021 07:34 PM
Nescafe
Mar 12, 2018 02:49 AM
hoodun
Jun 2, 2015 12:53 AM
hifipm
Mar 15, 2015 12:28 PM
solerydr
Jun 27, 2014 10:04 AM
