Programming ECM for XJR
Old May 30, 2024 | 10:37 AM
jagxjr's Avatar
Question Programming ECM for XJR
Can you program any ECM from 2004-2009 models cars to use it
in 2004 Jaguar XJR, or does it must be 2W93-10K975-EF SC
and with part #MB079700-9074?
Old May 31, 2024 | 12:14 PM
jagxjr's Avatar
BTW, a few years back I've asked question to which I got answers
which would have nothing to do with substance of post itself.
Maybe somebody can put together these 2 questions and come up
with answer.
Originally Posted by jagxjr
Why Jags have similar but different ECU part numbers?
For example: 2W93-10K975-EF and 2W93-10K975-TB
They both used on 2004 - 2005 X350 4.2 SC Jags but
EF have code MB079700-9074 and TB MB079700-9520
Does it mean that they ain't interchangeable and we have to stick to our model only?
Old Jun 3, 2024 | 06:14 PM
jagxjr's Avatar
Almost 300 visits and no one can come up with answer,
I can bet, on everybody's mind nowhere to be found,
Old Jun 4, 2024 | 12:30 PM
JagV8's Avatar
Only an experienced, quite old, jag tech might know & you may well be #1 attempting it. So, no replies.
Old Jun 4, 2024 | 02:52 PM
jagxjr's Avatar
Granted, not everyone ever have dealt with out of ordinary
programming issues but I'm sure that in 20 years since SC 2004 XJR
appeared on the market, some enthusiasts wouldn't ask themselves
"what if" and dig deep down to find an answer. Call it "human nature".
Old Jun 4, 2024 | 11:22 PM
xalty's Avatar
2005 model year has changeover stuff, str is a no-no because of low loss evap but xj probably yes. save your old VID block run immobilization in IDS go start the car you will have your answer.
if your old one is a no-comm i'm not writing the paragraph on how to fix your vid block
Old Jun 5, 2024 | 10:40 AM
jagxjr's Avatar
Am I missing something?
Thank you for your reply but how your post is related to
programming ECM from different model like XJ8 to XJR?
Old Jun 10, 2024 | 08:21 AM
OldKarz's Avatar
I believe part way through 2005 the architecture went from VID Block to CCF. Also used a different bus for programming so will be VIN dependent on which will work. That is why many clones and newer readers do not work on pre 2005s. Evidently there were also different ECUs for some countries - don't know why.
Old Jun 11, 2024 | 04:11 PM
jagxjr's Avatar
Simple logic says that hardware should be the same for every car of any
range of models which sharing years and VIN. It would be crazy to build
ECM hardware with different architecture for XJR, XJ8, S-type and so on.
Of course software is different for any given model to make sure it covers
particular model requirements, like for example XJR program covers a ton
of modulus, sensors supercharge, and so on, something is not part of XJ8
My queries are much more simpler then that.All I wanna to know if anyone
ever tried and succeed to install XJR software in XJ8?
Old Jun 11, 2024 | 05:16 PM
xalty's Avatar
ids identifies hardware you can’t put the wrong calibration into an xjr ecm, they are different period end of story. 06-09 ECMs are also totally different.
again man just get a used ECM from an 05 and older . cheap $40 mongoose clone, cracked sdd, run immo and you’re done.
Old Jun 11, 2024 | 06:15 PM
jagxjr's Avatar
I never said, I want to put something that doesn't belong to XJR.
I'm asking if it's possible to load XJR OS in XJ8 ECM and see it work
Why 05?
What's wrong with 04 from car with the same bundle of VIN numbers as mine?
aquifer
Sep 1, 2019 08:24 PM
mikebaker3
Jun 30, 2019 11:40 AM
b72hugh
XJ XJ12 ( X305 )
Jul 13, 2013 11:48 PM
