Programming Key Fob To Start Engine
Old Apr 17, 2014 | 03:51 PM
halwarlick's Avatar
Default Programming Key Fob To Start Engine
I have had my 2005 Jaguar XJ8L key fob programmed to unlock/lock my vehicle and have had it cut at Jaguar. The only thing is the key will not start the car. When I put it in accessory position, all of the lights come one like they are supposed to, but the vehicle will not start. We do, however, own a valet key that does start the car. How to we program the car to start the ignition? One other thing to note is that there is a flashing red light in the security center where it only normally beeps red when locked. But it does it constantly only when this new key is inserted into the ignition ant turned to accessory.
Old Apr 17, 2014 | 05:18 PM
Originally Posted by halwarlick
I have had my 2005 Jaguar XJ8L key fob programmed to unlock/lock my vehicle and have had it cut at Jaguar. The only thing is the key will not start the car. ..........
Welcome to the forum halwarlick,
Did you have the key cut AND programmed at Jaguar? If not, it needs to be programmed to the vehicle on the dealer SDD diagnostics or by an independent with similar level diagnostics.
If you did have both done by Jaguar, take the vehicle and key back to the dealership and give them a really hard time.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Apr 17, 2014 | 06:00 PM
psg's Avatar
psg
Check in the 'How To' at the beginning of this there are 3 articles on how to program, the 'everything you needed to know' the best one IMHO. You should be able to re-program the engine immobilizer if you have an existing key (Valet) .
Old Apr 17, 2014 | 06:14 PM
Cambo's Avatar
Easiest way to do this would be find a locksmith / key-cutting place that does tibbe keys, most decent places will be able to clone the transponder chip in your working key into the new one.
But I don't quite understand this...
You got a new key cut by a Jag dealer, they programmed the new remote, but didn't check that the key actually started the car. In that case i'd be taking it back (with all three keys, they will need them) and tell them to finish the job you paid them for...
hafren
Aug 30, 2023 03:42 PM
10 XF Premium
Sep 18, 2015 10:03 PM
tberg
Sep 7, 2015 07:32 AM
nelsonht
Aug 30, 2015 06:01 AM
Marccutler
Aug 27, 2015 05:11 PM
