Put the new Arnott stuts on they wont signal the pump to cut on??
Old Sep 26, 2015 | 01:40 PM
Collector1's Avatar
Default Put the new Arnott stuts on they wont signal the pump to cut on??
The new air struts are on and the pump is not receiving a signal to turn on. I don't have any message error on the dash, saying car is too low. Nothing. It is just baffling to me. I wonder it the electrical connection in one of the bags is defective? Any ideas? I have disconnected and reconnected the battery but sill the pump will not turn on. I know the pump is good because it was working right before I changed the struts ARGUHHHHHHHHHHHHHHHH
Old Sep 26, 2015 | 02:58 PM
Torrid's Avatar
Have you tried moving the car? Sometimes that will trigger it to adjust height.
Old Sep 26, 2015 | 03:56 PM
Collector1's Avatar
Default I drove it
That hasn't worked. I possibly could have moved the sensor and turned it the opposite way when the hub was off. Does anyone have a picture of their height sensor that they can email me or post? I noticed it was caught on the stop. Possibly it is either turned the opposite way or I have it in the wrong position. I put the arm below the bracket stop. Is this correct or incorrect? Should the plastic arm be above the stop. Or maybe try and move it the opposite way. The rear is sitting up just fine, looks high but it is possible its high because the low is sitting so low..
Old Sep 26, 2015 | 04:57 PM
Torrid's Avatar
Did you disconnect the battery before removing the ride height sensor? From my understanding if the sensor is disconnected while the car has power, the suspension ride height has to be recalibrated.
Old Sep 26, 2015 | 05:32 PM
Collector1's Avatar
Default It was a simple problem!
I looked at picture someone posted on the web and mine looked different. The arm had gotten dropped to the opposite direction causing the car to think it was to high. I removed the rubber moved the arm 160* and reconnected the rubber to the "A", arm and the shocks filled up. Total PERFECTION!!!! Right height, new 2010- current style bag and all is well in my world. I think these will last a very long, long time. Totally different construction and there isn't any noise over bumps. The old ones are bellow type exposed bags, these are covered and very little of the rubber is exposed. I'm very happy!!!! Thanks to all!!!!!!
No need to calibrate anything. All four corners sit perfectly at the same height!
Old Sep 27, 2015 | 03:04 PM
Fraser Mitchell's Avatar
The bellows you see on the Bilstein originals is not the air spring, it is just a protective cover; the diaphragm is inside.
Old Sep 28, 2015 | 03:52 AM
Collector1's Avatar
Default I have no clue as to what your referring to
These are not Bilstein assemblies but remanufactured oem original air assemblies that were originally a bellow style but were re designed for the 10-up XJ series and are now fully shrouded as well as a massive metal band over the bag to insure longevity, Also they are now Continental vers Goodyear
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
mbergen
Oct 23, 2019 10:26 PM
Jaguar Forums Editor
Jaguar Press release
Sep 5, 2015 10:08 AM
Sprayall
Sep 3, 2015 07:49 PM
