Question for the gearbox people
Old Nov 26, 2021 | 05:12 AM
Richardhw's Avatar
Default Question for the gearbox people
I have an issue with the gearbox on my 3.0 V6 SE. 2003 I have had it diagnosed as the valve body which I am having a bit of trouble finding one however I can get a complete box from an S type 3.0 V6 2003.
Is it likely to be the same or would that just be wishful thinking ?
Thanks.
Old Nov 26, 2021 | 05:53 AM
Fraser Mitchell's Avatar
If it's a 6HP26, then it is the same.
Old Nov 26, 2021 | 08:34 AM
Richardhw's Avatar
Thanks, gearboxes are an unknown for me.
Old Nov 26, 2021 | 10:16 AM
jackra_1's Avatar
The only possible issue is that the Mechatronics unit is not compatible between the two models. Unlikely to be the case and if there is an issue SDD could reflash the unit.
If there were an issue the unit from the original couild be swapped with no problem.
SDD will be needed in any case.
Old Nov 26, 2021 | 11:49 PM
Richardhw's Avatar
Thanks, there is an independent specialist fairly close to me who can sort that.
daz2708
Nov 14, 2021 10:47 PM
David1960
Oct 13, 2021 04:15 PM
Fermanaghman
Dec 18, 2012 08:11 PM
easydriveways
Aug 31, 2012 08:14 AM
