Quick help needed please
Old Jul 12, 2010 | 08:46 PM
UnklFungus's Avatar
Default Quick help needed please
I haven't searched, only because I am literally still trying to get started unpacking. On my 06 XJ8, all of a sudden the HVAC fan won't blow. I have looked in the owner's manual and checked all the fuses listed and they are all good. The touch screen shows that the fan motor is on it's highest setting, but no fan is turning. The car has sat for the last week or 10 days, but I don't know how to get it running.
Is there are reset? I can hear the blend doors moving from hot to cold, but that is all the action I am getting right now.
Thanks in advance,
UnklFungus
Old Jul 12, 2010 | 09:08 PM
Brutal's Avatar
you need to replace the fan blower module located behind the glove box. I have several new ones if you r interested pm me. half off
Old Jul 12, 2010 | 09:26 PM
UnklFungus's Avatar
Thanks! How much? Also, do you have a pic of what I am looking for?
Old Jul 13, 2010 | 09:54 AM
UnklFungus's Avatar
Could you PM me? I can't seem to be able to view your public profile, I keep geting a message telling me I don't have authorization to view it.
Old Jul 13, 2010 | 09:58 AM
Brutal's Avatar
youll have to wait till I get to work. Im going in late since Im getting concrete poured at the house this morning for a new patio.
Here are pics you wanted, you remove the glove box assembly and its mounted in the air duct above the blower assembly directly behind the glove box..
Attached Thumbnails Quick help needed please-p7130003.jpg   Quick help needed please-p7130004.jpg   Quick help needed please-p7130005.jpg
Old Jul 13, 2010 | 12:05 PM
UnklFungus's Avatar
I just realized I got the year wrong. It is an 04 XJ8, if that makes any difference.
Old Jul 13, 2010 | 02:33 PM
UnklFungus's Avatar
Thanks,
Do I remove the glove box assy by undoing the screws on the bottom of the GB hinge or do I undo the nuts holding the hinge on? Which is the best way?
Old Jul 13, 2010 | 02:44 PM
H20boy's Avatar
Fungus, I can PDF you the disassembly instructions from the 2005 version of the JTIS. If you want get the parts on the way, you can be ready to tear it apart when they arrive.
In fact, the CD is a good investment, you should consider picking one up from ebay...here's a link to the version that has your 04+ XJs...be careful, not all CDs have the latest XJ.
Old Jul 13, 2010 | 02:58 PM
UnklFungus's Avatar
Please do, the car belongs to my sister and if I do it myself, I'll save her a bunch of money, which would help her out. I'll look into the CD, thanks.
Old Jul 13, 2010 | 03:45 PM
williamsinhb's Avatar
This manual good for the 2006 as well
Old Jul 13, 2010 | 04:08 PM
Brutal's Avatar
04 is the same for the ac blower module
Old Jul 15, 2010 | 04:15 PM
equicor's Avatar
Just want to verify: are you saying that the JTIS CD for the 2004(.5) is the last and most current version available? That doesn't really surprise me but I'd like to be sure.
Also, H20boy mentioned that all CD's might not cover the 'latest XJ'; how doe one know what is the correct CD for an '06?
I see several on Ebay and what to make sure I buy the right one!
Old Jul 15, 2010 | 04:46 PM
H20boy's Avatar
just make sure the list of vehicles covers up to MY 2004 XJs, if it doesn't say if it does...don't get it.
That is the last CD available, after that, the source went online thru server database only, so us outsiders can't have access.
Many of the basics will be the same for years 04 and up, but just use it with caution, don't take it as gospel as the model years get newer from the 04.
Old Jul 15, 2010 | 05:10 PM
equicor's Avatar
Old Jul 15, 2010 | 11:12 PM
u102768's Avatar
That isn't strictly true, it is available on-line from Jaguar if you don't mind paying.
It was at JaguarTechInfo but is now at:
http://topix.jaguar.jlrext.com
JaguarTechInfo seemed to be free for a week or two at the end (possibly a mistake) so I had a good look at the X350 manual and there are, as you say, many changes as you go through the years.
Old Jul 15, 2010 | 11:23 PM
H20boy's Avatar
^ correct, I think it was just over $200 a year for full access to it.
Old Feb 5, 2011 | 03:25 PM
rhodietwo's Avatar
I too am having a problem with my blower. 04 XJ8. No air. I removed the blower. Switched it off then turning air on. Motor turned for 1 sec. Removed electric connection and checked voltage. 10 volt when switching air on then 1 volt within 1 second. While disconnected. Do I need a new blower and do you have one? Thanks.
philwarner
Oct 4, 2024 01:37 PM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
TC Johnson
Sep 2, 2015 09:30 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
