Radiator Hose Replacement & Cost
Old Jul 22, 2015 | 12:11 PM
2intense's Avatar
Default Radiator Hose Replacement & Cost
(2004 XJR - 54K miles)
I had a low coolant light. Took it to the dealer and they say I have an EGR Radiator Hose leakig at both ends and needs replacement. They say it's the hose that runs from front to back of engine and requires significant labor to remove and replace. They suggested replacing the other smaller hose that runs from radiator to engine as well as it shows signs of seepage at connection and will become week point when other hose is replaced.
quote is as follows:
1) EGR Hose $24
2) Small Hose $130
2) Labor to replace both hoses: $1200
WTF?
I know I am paying a premium as it is the dealer, but is this really that labor intensive?
Old Jul 22, 2015 | 03:38 PM
34by151's Avatar
If you have the supercharged engine yes it is a big job as the hose run under the supercharger and inlet manifold.
Its sill a big job on the non s/c but not that bad
My suggestion is to purchase the hose take it to an indy.
Again if you hav ethe S/C engine, it is also worth checking out the small 90 deg hose that goes from the block to the rear of the thermostat housing. A leak here looks like a valley hose issue but is a easy fix.
34by151
Old Jul 22, 2015 | 11:44 PM
2intense's Avatar
Well, this is a first for me...really, it's the first time in my life I have ever had a dealer (let alone a Jaguar dealer!) offer to do the job cheaper than everyone else?
I got estimates from 2 independent shops and they both quoted higher than the dealer!
Dealer Quote: @ $1400
Indy 1: @ $1800
Indy 2: @ $2000
Crazy!
....and yes, mine has the supercharger.
Old Jul 23, 2015 | 07:30 AM
Fraser Mitchell's Avatar
Unfortunately you have found the notorious little pipe that costs little to buy and lots to replace !! One does have to ask why Jaguar couldn't have used a more robust material for this pipe, bearing in mind it's inaccessible position on the engine.
JarodL
Mar 7, 2024 01:39 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
davidladewig
Sep 3, 2015 06:32 PM
XFR_Gold
Sep 2, 2015 12:24 PM
innzane
Sep 2, 2015 10:08 AM
