Rear driver door lock doesn't work
Old Jan 25, 2021 | 10:58 PM
Fernando's Avatar
Default Rear driver door lock doesn't work
Hello,
here is what is happening.
2008 vanden plas
The driver rear door does not unlock or lock with any of the following.
  • Fob
  • Lock button
  • When the car automatically locks/unlock when the car is put in park.
I hear a whirling sound when it's supposed to lock/unlock. The lock can be moved manually.
Any help with troubleshooting and solutions are much appreciated.
Old Jan 26, 2021 | 03:24 AM
meirion1's Avatar
Can you expand on what you mean by moving the lock manually.
Do you mean that you are able to lock/unlock the door using the interior chrome lever/button?
Old Jan 26, 2021 | 06:59 AM
Fernando's Avatar
Correct. If I disengage the lock by moving the button. The door will open with both the inside and outside handle
Old Jan 26, 2021 | 04:19 PM
meirion1's Avatar
In my experience locks fail when the microswitch in the actuator fails but
in your case because you can hear a noise when you try to lock the door,
with the fob for example, I can say that the microswitch is still working.
I assume that all other doors lock/unlock normally hence the problem is
probably still related to the rear door actuator and /or it's connecting cable.
I suggest that you need to investigate the cable connection first since
people have reported cases where the cable has been too tight preventing the
actuator from working properly.
Wiring and plug/socket problems are possible but unlikely.
If there is nothing out of place you may need to replace the actuator.
carzaddict
Sep 19, 2023 11:09 AM
ZenFly
Feb 19, 2022 09:29 AM
ZenFly
Jan 23, 2017 01:02 PM
RudyF6
Oct 5, 2011 06:25 PM
fourbyfourbyfar
Dec 26, 2009 08:02 AM
