Rear Driveshafts causing ABS issue
Hi All any ideas on alternative prices for rear driveshafts Xj Super V8 2004 G34349 chassis range. Mine have rotted and the abs rings are now touching the abs sensors as the ring has grown due to rust. If anyone knows what the left rear one part number is it would help me out. The right rear is C2C 22869. thanks Marc £1054 Ea is a bit steep
Maybe get yours rebuilt?
I don't think your in the US either?
I find Rock Auto has at least one of them listed for about $115.
They only show the LH side and list part number as C2P3969? But your right Jaguar is thru the roof on the price for this!! Around $800 each!!
Again I would call around locally and see if yours can be rebuilt.
If you live in Mansfield, UK, then Dave Marks Garages in Nottingham should be able to give you advice or even fix the problem. Rusting of a reluctor ring can be sorted out by removing the rust, surely ?
David Marks Garages - About Us
I've moved your question from General Tech Help to X350 forum. This is the place to post techncial questions about your model.
Do a google search for a company that makes reluctor rings
Found it for you:
https://www.reluctorrings.com/contact
Found it for you:
Ralph Hemp
26
Aug 11, 2017 08:42 PM
