Repair sunroof without dropping the headliner
Old Oct 5, 2013 | 05:44 PM
Mongoose's Avatar
Default Repair sunroof without dropping the headliner
If your problem is broken lifter arms... this is possible to do without dropping the headliner.
If your problem is broken lifter arms, they can be purchased from The Sunroof Doctor - Your source for replacement sunroof & t-top parts!, they come attached (by pop rivet) to a guide that slides in the sunroof track.
If you remove the glass, and drill out the pop rivets from the cabin side with a 1/8" bit, on both the broken and replacement parts, you can attach the new lifter arms to the guide using an M3 Machine Screw, Washer and Locking Nut.
Total time to repair was about two hours, including cleaning out all the broken plastic parts from the old arms.
Sunroof Doctor also supplied some instructions with the procedure on how to realign the arms, reattach the glass and calibrate, I followed those and I now have a working sunroof again
I have some pictures somewhere and will upload them soon. Hope this helps someone else avoid dropping their headliner unnecessarily.
M
Old Oct 6, 2013 | 12:59 AM
BlackKat's Avatar
Thanks Mongoose! This is exactly what I needed. I visited the link but am having trouble finding the parts for the X350. Can you post the part numbers?
Old Oct 6, 2013 | 03:04 PM
Mongoose's Avatar
The part number i removed was 1W98-A-3101-B, however the replacement part was a very slightly different number. Although the website didn't list the XJ, they knew the model when I called to order.
I did find an exploded part diagram on the webasto website when I was buying the part, but the site seems to have changed since then. If I find it again I will post that.
Old Oct 6, 2013 | 07:11 PM
BlackKat's Avatar
Awesome. What's the replacement part number?
Thanks again!
Old Dec 17, 2013 | 12:50 AM
bobbyg's Avatar
My sunroof is not working. I found a broken part on the drivers side. I believe its the slider that you mentioned. If you find those photos that you mentioned, could you please post them. Also the exploded parts diagram would be a big help. I could not locate it on the web. Thanks.
99xk8guy
Sep 29, 2025 10:51 PM
Jose
Dec 18, 2021 08:16 AM
Tony K
Apr 2, 2020 11:55 AM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
graham11
Sep 7, 2015 03:04 PM
