Replaced X350 Front Bearings
#62
#63
#64
Received 12,767 Likes
Hi Paul,
I recently replaced the front right wheel bearing on an X100 because both I and the owner were certain the noise was loudest from the right side. After replacing the right bearing, the noise reduced slightly, but the worst of the noise remained. I pulled the wheel, caliper and rotor off the left front bearing, and sure enough, it was even worse than the right one had been. You might check your opposite bearing just to rule it out. The only way I know of for a definitive diagnosis is to remove the mass loading of the wheel and rotor (the caliper has to come off too). Then spin the hub by hand and feel/listen for any roughness, grittiness, irregular resistance, etc.
Other suspects I can think of are a problem with one or more of the belt-driven accessories (e.g. A/C compressor), a bad lower shock bushing or lower control arm bushing, a groaning ABS modulator, perhaps combined with a tire whose tread is noisy. Do any of those seem possible?
Cheers,
Don
meirion1 (05-27-2018)
#65
Hi Paul,
I recently replaced the front right wheel bearing on an X100 because both I and the owner were certain that was where the noise was coming from. The noise reduced slightly, but the worst of the noise remained. I pulled the wheel, caliper and rotor off the left front bearing, and sure enough, it was even worse than the right one had been. You might check your opposite bearing just to rule it out. The only way I know of for a definitive diagnosis is to remove the mass loading of the wheel and rotor (the caliper has to come off too). Then spin the hub by hand and feel/listen for any roughness, grittiness, irregular resistance, etc.
Cheers,
Don
Cheers,
Don
#66
Hi Paul,
The wheel and lug nuts, when properly torqued, are perfectly sufficient to hold the rotor in position. Even if the rotor originally had one or more screws that secured it to the hub, or washer-type pushnuts on one or more studs for the same purpose, the screws or pushnuts are rarely replaced by brake shops the first time the rotor needs to be removed.
Cheers,
Don
#67
Some brands of rotors do not have screw holes
Hi Paul,
Cheers,
Don
Cheers,
Don
The Meyle were cheap. 150.00 for all four with delivery Seem to be fine, 5 years and 30,000 miles so far.
#68
#69
BrentGardner
28
04-26-2024 03:08 AM
philwarner
12-06-2021 07:13 AM
Fraser Mitchell
10-01-2015 04:06 AM
